installing tptp [message #53892] |
Wed, 15 February 2006 18:43  |
Originally posted by: bruce.trask.prismtech.com
!SESSION 2006-02-15
18:39:23.52 ------------------------------------------------
eclipse.buildId=M20050929-0840
java.version=1.5.0_03
Command-line arguments: -os win32 -ws win32 -arch x86
I have followed the directions from
http://www.eclipse.org/tptp/home/downloads/installguide/Inst allGuide41.html
I have all prerequisites but get the following on the error log.
Any suggestions:
!ENTRY org.eclipse.pde.core 2 1 2006-02-15 18:39:58.312
!MESSAGE Problems encountered while PDE was scanning the Target Platform
!SUBENTRY 1 org.eclipse.hyades.execution.nl1 2 2 2006-02-15 18:39:58.312
!MESSAGE Missing Fragment Host: org.eclipse.hyades.execution
!SUBENTRY 1 org.eclipse.hyades.execution.nl2 2 2 2006-02-15 18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.execution.nlBidi 2 2 2006-02-15 18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.adapter.nl1 2 2 2006-02-15
18:39:58.312
!MESSAGE Missing Fragment Host: org.eclipse.hyades.logging.adapter
!SUBENTRY 1 org.eclipse.hyades.logging.adapter.nl2 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.adapter.nlBidi 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.adapter.ui.nl1 2 2 2006-02-15
18:39:58.312
!MESSAGE Missing Fragment Host: org.eclipse.hyades.logging.adapter.ui
!SUBENTRY 1 org.eclipse.hyades.logging.adapter.ui.nl2 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.adapter.ui.nlBidi 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.core.nl1 2 2 2006-02-15 18:39:58.312
!MESSAGE Missing Fragment Host: org.eclipse.hyades.logging.core
!SUBENTRY 1 org.eclipse.hyades.logging.core.nl2 2 2 2006-02-15 18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.core.nlBidi 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.core.sample.nl1 2 2 2006-02-15
18:39:58.312
!MESSAGE Missing Fragment Host: org.eclipse.hyades.logging.core.sample
!SUBENTRY 1 org.eclipse.hyades.logging.core.sample.nl2 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.core.sample.nlBidi 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.parsers.nl1 2 2 2006-02-15
18:39:58.312
!MESSAGE Missing Fragment Host: org.eclipse.hyades.logging.parsers
!SUBENTRY 1 org.eclipse.hyades.logging.parsers.nl2 2 2 2006-02-15
18:39:58.312
!SUBENTRY 1 org.eclipse.hyades.logging.parsers.nlBidi 2 2 2006-02-15
18:39:58.312
Thanks in advance,
Bruce
Re: installing tptp [message #53970 is a reply to message #53892] |
Fri, 17 February 2006 18:19  |
"I have all the prerequisites..." but java.version of 1.5 is not on that
list. Okay, so let's go with the stock answer when people ask about Java
1.5 ... "it should work" ... and see what else it might be.
How did you install the pre-reqs? Download and unzip? Or update manager?
If the former, did you try starting -clean??
M2050929-0840 is Eclipse 3.1.1, as I recall. What version of TPTP did
you get? 4.1.0? 4.1.0.1??
RDS
Bruce Trask wrote:
> !SESSION 2006-02-15
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Any suggestions:
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> 18:39:58.312
> Thanks in advance,
> Bruce
FUDForum. Page generated in 0.03137 seconds
