Home » Modeling » OCL » About OCL name expressions
About OCL name expressions [message #53836] Tue, 15 April 2008 05:16 Go to next message
Hi Christian,
Working around the new EValidator infraestructure I have noticed that
now OCLExpressions may not have a name, and the validator doesn't
complain about that, That's good ;). However, when there is a problem
with an OCLExpression itself, the produced message is not clear (a null
name appears for the unnamed OCLExpressions)
I suggest you overriding getName method from OCLExpressionImpl.
Something like this:
/* (non-Javadoc)
* @see org.eclipse.emf.ecore.impl.ENamedElementImpl#getName()
public String getName() {
String name = super.getName();
return (name == null) ? eClass().getName() : name;
If you considere it, I could arise an enhancement feature for that ;).
Adolfo.
Re: About OCL name expressions [message #53861 is a reply to message #53836] Tue, 15 April 2008 09:22 Go to previous messageGo to next message
Hi, Adolfo,
I'm afraid I don't understand the problem. If the validator doesn't
complain about an OCLExpression not having a name, then why would it
produce a message? Or, do you mean for other problems that may be
reported?
In any case, I don't think that the metaclass name makes sense as a name for
an element. Keep in mind that the client of the Diagnostician can provide
an EValidator::SubstitutionLabelProvider to customize the string
representation of objects in the problem messages. You might use that to
substitute, say, the un-parsed expression text (probably part of it only,
truncated by an ellipsis) for OCLExpressions.
Christian
Adolfo Sánchez-Barbudo Herrera wrote:
> Hi Christian,
> /* (non-Javadoc)
> @Override
> Cheers,
> Adolfo.
Re: About OCL name expressions [message #53884 is a reply to message #53861] Tue, 15 April 2008 10:57 Go to previous messageGo to next message
Hi Christian,
Sorry for my bad explanations and my poor knowledge about EValidator
framework;P. Maybe an example would have helped, I'll will explain my
concrete example:
I have a Metaclass VariableInitExp ( -> ImperativeExpression ->
OCLExpression) with a required reference called referredVariable. If
this referredVariable is not set in an instance of it, the Validator
throws the following message error:
Validator-ERROR in org.eclipse.emf.ecore; CompleteExample.qvto:79 : The
required feature 'referredVariable' of
'CompleteExample.eqvtoperational::aTransformation::main::Ope rationBody:: <null>'
must be set
This "<null>" value is due to the absence of a name for the
OCLExpression (in this case VariableInitExp). I agree that a lot of
expressions don't need a name, but the main reason for that is that the
own expression is meaningful to identify it, so I think that its
metaclass's name could make sense for all of them...
So, for the previous case we could have the following report:
'CompleteExample.eqvtoperational::aTransformation::main::Ope rationBody::VariableInitExp'
must be set
So when getting the name of every VariableInitExp instance, we could
obtain a proper identifying name. Note that when persisting to a
resource, the name is not serialized since the name is not set at all
(I'm not sure if I have been clear :S).
Besides, if you look at the error reporting, OperationBody is included
as the name for OperationBody's instance (However, it's is not a
NamedElement). I'm not sure of that, but probably this is the policy
(taking its MetaClass name) for all elements which are not NamedElements ...
Anyway for this concrete purpose, perhaps I could achieve a better error
reporting from the validator, making use of that
SubstituionLabelProvider, as you mention. As I said you I'm a newbie
trying to configure the validation of models for a concrete metamodel,
so I don't have a good point to get the better way to solve the problems
with it.
Anyway, a bugzilla enhancement will probably be needed since the OCL
EValidator will not properly report the problems concerning unnamed
OCLExpressions. So it's a problem which will need to be solved.
Adolfo.
Christian W. Damus escribió:
> Hi, Adolfo,
> reported?
> Cheers,
> Christian
>> Hi Christian,
>> /* (non-Javadoc)
>> @Override
>> Cheers,
>> Adolfo.
Re: About OCL name expressions [message #53905 is a reply to message #53884] Tue, 15 April 2008 11:21 Go to previous messageGo to next message
Hi, Adolfo,
I see. Where did the qualified name come from in the error message? Is
that provided by the default substitution-label provider in the
diagnostician?
The problem with providing a non-null default name is that, unless it is
actually specified as the default in the Ecore model (the OCLExpression
EClass), it will be written out when an expression is serialized. That's
not great, because it should behave consistently like a default, and not be
written.
I think the better approach will be to see whether the '<null>' is provided
by EMF by default, and whether that could be changed (in EMF) to
show '<VariableInitExp>' instead (according to the EClass name). I really
do think the solution needs to be implemented in the validation framework,
not in the metamodel.
Christian
> Hi Christian,
> concrete example:
> must be set
> must be set
> with it.
> Cheers,
> Adolfo.
-----8<-----
Re: About OCL name expressions [message #53925 is a reply to message #53905] Tue, 15 April 2008 12:27 Go to previous messageGo to next message
> Hi, Adolfo,
> diagnostician?
Certainly, I don't exactly know, but it should be...Anyway I'll look
into that to have a better point about it (Perhaps Ed Merks, could give
us some help ;P).
What I'm sure:
- Is that the default implementation (substitution-label or whatever)
makes use of the getName() method (from ENamedElement) to display the
errors. I overwrote it, to check it.
> written.
Note that overwriting the getName method to return a no null name for a
oclexpression, is not the same that setting a name for it. So when
saving the element in a Resource, since the field is still set to null,
it will not be serialized. At least that is the conclusion I got when I
checked that my unnamed ImperativeExpressions don't have (serialized)
name after overwriting the getName method ;).
Yes, I agree. It would probably be better working around the
OCLValidator (and the displayed messages), at least to solve this
concrete issue. I don't know if there will be more problems surrounding
the unnamed OCL Expressions.
Anyway, I'll arise a bugzilla bug relating that OCL EValidator doesn't
properly display errors when dealing with unnamed OCL Expressions. And
I'll look into the diagnostician reporting error.
Adolfo.
> Cheers,
> Christian
>> Hi Christian,
>> concrete example:
>> must be set
>> must be set
>> with it.
>> Cheers,
>> Adolfo.
> -----8<-----
Re: About OCL name expressions [message #54079 is a reply to message #53905] Fri, 18 April 2008 02:43 Go to previous messageGo to next message
The name in EValidator diaganostics is provided by EObjectValidator.getObjectLabel which normally redirects to a
EValidator.SubstitutionLabelProvider. Within the UMLX framework a CSTFormattingHelper is used
that inherits from OCL's AbstractFormattingHelper and implements EValidator.SubstitutionLabelProvider.
CSTFormattingHelper redirects getObjectLabel to formatQualifiedName.
[It might be beneficial if AbstractFormattingHelper implemented EValidator.SubstitutionLabelProvider.]
It is formatName and formatQualifiedName that are responsible for rendering user-friendly labels, so it is
M6 bit-rot that causes this annoyance. At present formatName has a simple ENamedElement test that
trusts the name. AbstractFormattingHelper.formatName needs to do something better for anonymous
ENamedElements, such as restoring the referred variable name for a VariableExp and providing perhaps
a length-limited string value for a StringLiteralExp.
Re: About OCL name expressions [message #54103 is a reply to message #54079] Fri, 18 April 2008 04:41 Go to previous message
Yeah !!! ;)
Probably ;)
Well. Since it's a generic abstract formatter, it isn't probably so bad
showing a null when a ENamedElement doesn't have value. It can be a good
way to detect some bugs when creating AST.
The comments you add, could be a good reference for any
OCLFormattingHelper, which we should extend. Anyway I think that the
name of the metaclass is a sufficient name for them (f.i. a large string
could be extremely long for showing as an error. Showing a
StringLiteralExp should suffice).
Adolfo.
Previous Topic:OCL Validator error.
Next Topic:Operation return values
Current Time: Tue Jul 08 08:50:25 EDT 2025
Powered by FUDForum. Page generated in 0.09059 seconds
