Home » Eclipse Projects » Eclipse Platform » RMI failure when plugin classpaths have spaces
RMI failure when plugin classpaths have spaces [message #4792] Tue, 22 April 2003 19:34 Go to next message
We currently have eclipse plugins that communicate with a remote server via
RMI. There appears to be a bug in the Eclipse platform that fails to URL
encode
whitespaces when determining the pluginclassloader's classpath. Since
whitespaces
are not allowed in URLs, it appears that the responsibility lies in the
Eclipse
platform to properly encode these URLs for us. If eclipse
2.x is currently installed in a directory w/ spaces in 'em, our plugin fails
to work with the following exception:
"java.rmi.UnmarshalException: error unmarshalling arguments; nested
exception is:
java.net.MalformedURLException: no protocol:
Files/eclipse/plugins/myplugin/foo.jar
!STACK 0
java.rmi.ServerException: RemoteException occurred in server thread; nested
exception is:
exception is:
There is a bug currently opened for this
http://bugs.eclipse.org/bugs/show_bug.cgi?id=22395 (currently a P3)
This seems like a pretty critical bug that needs to be addressed quickly.
Anybody else affected by this?
greg
Re: RMI failure when plugin classpaths have spaces [message #28752 is a reply to message #4792] Thu, 08 May 2003 05:24 Go to previous message
Originally posted by: giherf.voila.fr
I dn't know if it's possible,
but for OS, you must use : "
pearhaps, include " in the path :
for example :
C:\mes documents\giher
"C:\mes documents\giher"
URL.getFile() : String
use : String path = "\""+ URL.getFile() + ""\""
but, i d'nt know, if your fonction accept other object as URL or String .
good luck;
> encode
> whitespaces
> Eclipse
> exception is:
> !STACK 0
> exception is:
> exception is:
> Thanks
> greg
Previous Topic:[ANN] Jetty Launcher plugin 1.0.2
Next Topic:Surely the Search code can't be that badly factored?
Current Time: Sat Jul 26 18:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.03464 seconds
