Home » Eclipse Projects » GEF » TemplateTransferDropTargetListener
TemplateTransferDropTargetListener [message #53817] Sun, 12 January 2003 07:00 Go to next message
I want to be able to restrict what templates can be dropped on what targets,
but I'm not sure of the best way to do this.
GEF is implemented so that a drop is enabled if any EditPart is at the
current position, but I need to be able to change this behaviour.
One option would be to override
AbstractTransferDropTargetListener#isEnabled() and then check the edit
policy for the target.
Is this the best approach or are there a better methods.
John.
Re: TemplateTransferDropTargetListener [message #54026 is a reply to message #53817] Sun, 12 January 2003 14:51 Go to previous message
You could override getTargetEditPart(Request) in your layout edit policy (i.e.
LogicXYLayoutEditPolicy). If the request type is REQ_CREATE, then you could look at the host and
the template and return null if they don't match up. Otherwise, delegate to
super.getTargetEditPart(Request).
Eric
> John.
Previous Topic:How create a File extension in gef to GEF Editor
Next Topic:ConnectionLayer in GEF
Current Time: Sat Jul 26 17:49:25 EDT 2025
Powered by FUDForum. Page generated in 0.03801 seconds
