Incremental update of the facet's list [message #53814] |
Wed, 29 September 2004 07:26  |
I have a problem with updating the list of facets after adding a new facet
to the facet contents. Here is the corresponding code snippet:
// load a schema
XSDSchema schema = load("test.xsd");
// Incrementally update the schema after each edit change
schema.setIncrementalUpdate(true);
// Build a new simple type and add it to the loaded schema
XSDSimpleTypeDefinition baseType = (XSDSimpleTypeDefinition)
schema.getTypeDefinitions().get(0);
XSDSimpleTypeDefinition simpleType = XSDFactory.eINSTANCE
.createXSDSimpleTypeDefinition();
simpleType.setBaseTypeDefinition(baseType);
schema.getContents().add(simpleType);
// Create a new facet and add it to the type
XSDMinLengthFacet minLength =
XSDFactory.eINSTANCE.createXSDMinLengthFacet();
minLength.setValue(10);
simpleType.getFacetContents().add(minLength);
// Print the facets of the type: MinLength isn't contained in the list
System.out.println(simpleType.getFacets());
// Enforce an update. Shouldn't be necessary because of the incremental
update
schema.update();
// Print the facets: Now MinLength is contained
Shouldn't the manual update be unnecessary because the incremental update
is set to true? Or did I miss something in the JavaDoc or in my code?
Cheers
Klaas
Re: Incremental update of the facet's list [message #53841 is a reply to message #53814] |
Wed, 29 September 2004 08:49   |
--------------000401000803020308050008
Klaas,
It's a bug. Please open a bugzilla. The following change is needed:
Index: XSDSimpleTypeDefinitionImpl.java
RCS file:
/home/technology/org.eclipse.xsd/plugins/org.eclipse.xsd/src /org/eclipse/xsd/impl/XSDSimpleTypeDefinitionImpl.java,v
retrieving revision 1.3
diff -u -r1.3 XSDSimpleTypeDefinitionImpl.java
--- XSDSimpleTypeDefinitionImpl.java 13 Jun 2004 11:52:17
-0000 1.3
+++ XSDSimpleTypeDefinitionImpl.java 29 Sep 2004 12:47:13 -0000
@@ -2059,7 +2059,8 @@
protected void adoptContent(EReference eReference,
XSDConcreteComponent xsdConcreteComponent)
super.adoptContent(eReference, xsdConcreteComponent);
- if (eReference ==
XSDPackage.eINSTANCE.getXSDSimpleTypeDefinition_Contents())
+ if (eReference ==
XSDPackage.eINSTANCE.getXSDSimpleTypeDefinition_Contents() ||
+ eReference ==
XSDPackage.eINSTANCE.getXSDSimpleTypeDefinition_FacetContent s())
traverseToRootForPatching();
@@ -2076,7 +2077,8 @@
protected void orphanContent(EReference eReference,
super.orphanContent(eReference, xsdConcreteComponent);
- if (eReference ==
+ if (eReference ==
+ eReference ==
Klaas Dellschaft wrote:
>Hi,
>// load a schema
>update
>schema.update();
>Cheers
>Klaas
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Klaas,<br>
<br>
It's a bug.
Re: Incremental update of the facet's list [message #54122 is a reply to message #54097] |
Thu, 14 October 2004 10:25  |
Klaas,
Not yet. But there should be a driver later today. (We had build
problems last week.) When we make a driver available we change the
bugzilla state to fixed and add a comment indicating which driver the
fix is in.
>Hi,
>is this fix available in any of the binary distributions of XSD or is it
>only commited to CVS at the moment? It seems to me that the current build
>of XSD is from 2004/09/17.
>Cheers
>Klaas
Re: Incremental update of the facet's list [message #591991 is a reply to message #53814] |
Klaas,
RCS file:
-0000 1.3
- if (eReference ==
+ if (eReference ==
+ eReference ==
- if (eReference ==
+ if (eReference ==
+ eReference ==
>Hi,
>// load a schema
>update
>schema.update();
>Cheers
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
It's a bug.
Re: Incremental update of the facet's list [message #592138 is a reply to message #54097] |
Klaas,
fix is in.
>Hi,
>Cheers
>Klaas
FUDForum. Page generated in 0.28007 seconds
