Home » Eclipse Projects » DTP » Problem with Schema details
Problem with Schema details [message #4771] Wed, 02 November 2005 23:36 Go to next message
Originally posted by: subhash.bhushan.gmail.com
Hi all,
I am currently using the latest eclipse.datatools plugin, with Oracle 10g.
I
am able to connect to the database successfully, and the tree structure
displays all the schemas in the database connected to. But I am not able
to view any objects in the schemas.
Is this a bug, or am is any configuration wrong?
I am using Eclipse 3.1 (JBoss IDE), with JRE 1.5.
Thanks in advance,
Subhash Bhushan.
Problem with Schema details - Plugin list [message #4841 is a reply to message #4771] Wed, 02 November 2005 23:39 Go to previous messageGo to next message
Here is the list of plugins that I have...
org.eclipse.datatools.connectivity.db.generic_0.0.2
org.eclipse.datatools.connectivity.ui_0.0.2
org.eclipse.datatools.connectivity_0.0.2
org.eclipse.datatools.modelbase.dbdefinition_0.7.0
org.eclipse.datatools.modelbase.edit_0.7.0
org.eclipse.datatools.modelbase.sql_0.7.0
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #4910 is a reply to message #4841] Thu, 03 November 2005 10:19 Go to previous messageGo to next message
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
The generic JDBC connection profile is not yet integrated with the SQL
model, so this is the expected outcome at this time (please refer to
http://www.eclipse.org/newsportal/article.php?id=142&gro up=eclipse.dtp#142
for details). Once the integration is complete (watch for an iteration
build announcement about this), then you will be able to see the expected
contents.
John Graham
Eclipse Data Tools Platform PMC
Re: Problem with Schema details - Plugin list [message #4980 is a reply to message #4910] Thu, 03 November 2005 11:53 Go to previous messageGo to next message
"John Graham" <jograham@sybase.com> wrote in message
news:e68cd8b0c45abca4c53cef3964a0e067$1@www.eclipse.org...
> > Thanks and Regards,
> > Subhash Bhushan.
> Subhash,
> contents.
> John Graham
John,
Thank you very much for the input.
Though I have enough and more enthusiasm to join you in your endeavor, I do
not have the time to dedicate for the task. But I promise to play the
Devil's Advocate by supplying you with ample reports of bugs.
Wishing you guys all the best in your race against time,
Hope to join you sometime in the near future,
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #5047 is a reply to message #4980] Thu, 03 November 2005 17:21 Go to previous message
> John,
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
We welcome Devil's Advocates, to whatever extent of time they can
contribute to DTP! :-)
Looking forward to working with you to insure that DTP meets the feature
and quality expectations of the community.
John Graham
Problem with Schema details - Plugin list [message #568045 is a reply to message #4771] Wed, 02 November 2005 23:39 Go to previous message
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #568092 is a reply to message #4841] Thu, 03 November 2005 10:19 Go to previous message
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
contents.
John Graham
Re: Problem with Schema details - Plugin list [message #568125 is a reply to message #4910] Thu, 03 November 2005 11:53 Go to previous message
> > Thanks and Regards,
> > Subhash Bhushan.
> Subhash,
> contents.
> John Graham
John,
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #568152 is a reply to message #4980] Thu, 03 November 2005 17:21 Go to previous message
> John,
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
John Graham
Previous Topic:Problem with Schema details
Next Topic:Fourth M1 Iteration Build posted
Current Time: Tue Jul 08 00:04:24 EDT 2025
Powered by FUDForum. Page generated in 0.15488 seconds
