install problem: MissingResourceException [message #53692] |
Thu, 08 May 2003 16:14 |
Originally posted by: info.trilobiet.nl
Hello world!
Just tried to install eclipse for the 81.000nd time but I still get a
MissingResourceException.
I use the Sun SDK 1.4.1_02 (jre)
Both SDK and Eclipse are located on my D:\ drive, while Windows2000 is
located at C:\
eclipse.exe -vm D:/!apps/sun/java etc.etc. doesn't solve the problem. A
workspace dir is created, but then installation stops and an errorlog is
generated stating the following:
java.lang.ExceptionInInitializerError
org.eclipse.core.internal.runtime.InternalPlatform.loadRegis try(InternalPlatform.java:677)
org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(InternalPlatform.java:574)
org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader.java:1011)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:838)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.util.MissingResourceException: Can't find bundle for
base name org.eclipse.core.internal.runtime.messages, locale en_US
java.util.ResourceBundle.throwMissingResourceException(Resou rceBundle.java:804)
at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:7 73)
at java.util.ResourceBundle.getBundle(ResourceBundle.java:538)
at org.eclipse.core.internal.runtime.Policy.<clinit>(Policy.java:19)
... 16 more
Apparently installation can't find these resources but I cannot figure
out how to solve this.
Any help please?
Richard
FUDForum. Page generated in 0.04368 seconds
