Home » Language IDEs » Java Development Tools (JDT) » Multiple ClasspathContainers, Settings
Multiple ClasspathContainers, Settings [message #53679] |
Tue, 10 June 2003 04:17  |
Originally posted by: j.verschoor.nefli.nl
I've created a LibraryFolderClasspathContainer, but now I've stumbled into a
problem:
Sometimes, you maybe would like to specify more than 1 folder.
Right now I've solved this problem by getting the contents of both folders.
Maybe someone has a better solution for this.
Also, I was wondering where to store the info of the classpath.
Right now I'm doing javaProject.setOption(), and before that a call to
JavaModelManager.OptionNames.add() with my own preference id.
This works, but I don't like it.
Any help would be appreciated. Btw, where can I submit my code for eclipse?
Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #58329 is a reply to message #56736] |
Mon, 16 June 2003 05:28   |
Ok, I'll file a bug report + attachement later this day. I don't have the
code near me.
"Martin Aeschlimann" <martin_aeschlimann@ch.ibm.com> wrote in message
news:3EEA10E0.7030202@ch.ibm.com...
> To quickly answer the question about how to submit code:
> Create a bug report and add your code as an attachment.
> File it to JDT-UI and I'll have a look at it; we are interested to add
> folder containers to JDT!
> Thanks
> Martin
> Joris Verschoor wrote:
> > any one?
> > "Joris Verschoor" <j.verschoor@nefli.nl> wrote in message
> > news:bc43vm$smn$1@rogue.oti.com...
> >>Hello,
into
> > a
> >>problem:
> > folders.
> > eclipse?
> >>Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #61479 is a reply to message #58329] |
Thu, 19 June 2003 03:31   |
Well, my internet connection at home (Chello) is down for a couple of days.
Hopefully I'll get online again this weekend. If so, I'll also create a
seperate plugin here. Does anybody have any preference of the classname? the
JREClasspathContainer is in org.eclipse.jdt.launching or something..
news:bck2du$ntr$1@rogue.oti.com...
> code near me.
> > Thanks
> > Martin
> > > any one?
> > >>Hello,
> into
> > > a
> > >>problem:
> > > folders.
> > > eclipse?
> > >>Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #68747 is a reply to message #63863] |
Fri, 27 June 2003 09:11  |
Awesome -- I think the best use of this would be to be able to create a
reusable library folder of external stuff that any project could include.
(For example, all of the gazillion jars needed to work with weblogic portal
Thanks!
-- Scott
"Joris Verschoor" <j.verschoor@insomniq.com> wrote in message
news:bd1iv4$78p$1@rogue.oti.com...
> Here's a version for all of you to check out, just unpack in your eclpise
> folder.
> I've created a bug 39198 and submitted the code.
> There are a few things left to do:
> -short cut for browse
> -refactor to another package
> -the container only supports folders from the current project, I don't
know
> if others would like to be able to choose folders from other projects, but
I
> didn't.. But if anybody wants that, let me know.
Current Time: Sun Aug 31 21:14:36 EDT 2025
Powered by FUDForum. Page generated in 0.03907 seconds
