removing global elements from XSDSchema [message #53632] |
Tue, 28 September 2004 11:45  |
Originally posted by: robinnt.us.ibm.com
When removing a global element from the XSDSchema will anonymous complex
types, particles, sequences, facets, and child elements be removed and
garbage collected or does each need to be explicitly removed from their
containers.
For example:
<xsd:element name=Address>
<xsd:complexType>
<vsequence>
<xsd:element name="street" type="string">
<xsd:element name="city" type="string">
<xsd:element name="state" type="string">
<xsd:element name="zip">
<xsd:simpleType>
<xsd:restriction base="xsd:positiveInteger">
<xsd:maxExclusive value="100000"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
Is this code sufficient to remove the element "Address" and assure all the
referenced to the underlying objects have been removed so they can be
garbage collected.
xsdSchema.getContents.remove(elementAddress);
Otherwise, should I drill down through the underlying objects and remove
each individually to make sure all referenced have been removed so the objec
ts will be garbage collected.
Thanks.
Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #53760 is a reply to message #53658] |
Tue, 28 September 2004 16:56  |
Ok thank you.
Robin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cjc1ho$qva$1@eclipse.org...
> Robin,
> It should be sufficient to remove a parent, since that will (typically)
> result in all the children becoming unreachable and hence collectible.
> >containers.
> >For example:
> > <xsd:complexType>
> > <vsequence>
> > <xsd:simpleType>
> > </xsd:restriction>
> > </xsd:simpleType>
> > </xsd:element>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:element>
the
> >garbage collected.
objec
> >Thanks.
> >Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #591911 is a reply to message #53632] |
Tue, 28 September 2004 12:00  |
Robin,
>containers.
>For example:
> <xsd:complexType>
> <vsequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
></xsd:element>
>garbage collected.
>Thanks.
>Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #591958 is a reply to message #53658] |
Ok thank you.
Robin
> Robin,
> >containers.
> >For example:
> > <xsd:complexType>
> > <vsequence>
> > <xsd:simpleType>
> > </xsd:restriction>
> > </xsd:simpleType>
> > </xsd:element>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:element>
the
> >garbage collected.
objec
> >Thanks.
> >Robin Noble-Thomas
FUDForum. Page generated in 0.07481 seconds
