Home » Archived » XML Schema Definition (XSD) » removing global elements from XSDSchema
removing global elements from XSDSchema [message #53632] Tue, 28 September 2004 11:45 Go to next message
Originally posted by: robinnt.us.ibm.com
When removing a global element from the XSDSchema will anonymous complex
types, particles, sequences, facets, and child elements be removed and
garbage collected or does each need to be explicitly removed from their
containers.
For example:
<xsd:element name=Address>
<xsd:complexType>
<vsequence>
<xsd:element name="street" type="string">
<xsd:element name="city" type="string">
<xsd:element name="state" type="string">
<xsd:element name="zip">
<xsd:simpleType>
<xsd:restriction base="xsd:positiveInteger">
<xsd:maxExclusive value="100000"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
Is this code sufficient to remove the element "Address" and assure all the
referenced to the underlying objects have been removed so they can be
garbage collected.
xsdSchema.getContents.remove(elementAddress);
Otherwise, should I drill down through the underlying objects and remove
each individually to make sure all referenced have been removed so the objec
ts will be garbage collected.
Thanks.
Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #53658 is a reply to message #53632] Tue, 28 September 2004 12:00 Go to previous messageGo to next message
Robin,
It should be sufficient to remove a parent, since that will (typically)
result in all the children becoming unreachable and hence collectible.
>containers.
>For example:
> <xsd:complexType>
> <vsequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
></xsd:element>
>garbage collected.
>Thanks.
>Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #53760 is a reply to message #53658] Tue, 28 September 2004 16:56 Go to previous message
Ok thank you.
Robin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cjc1ho$qva$1@eclipse.org...
> Robin,
> >containers.
> >For example:
> > <xsd:complexType>
> > <vsequence>
> > <xsd:simpleType>
> > </xsd:restriction>
> > </xsd:simpleType>
> > </xsd:element>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:element>
the
> >garbage collected.
objec
> >Thanks.
> >Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #591911 is a reply to message #53632] Tue, 28 September 2004 12:00 Go to previous message
Robin,
>containers.
>For example:
> <xsd:complexType>
> <vsequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
></xsd:element>
>garbage collected.
>Thanks.
>Robin Noble-Thomas
Re: removing global elements from XSDSchema [message #591958 is a reply to message #53658] Tue, 28 September 2004 16:56 Go to previous message
Ok thank you.
Robin
> Robin,
> >containers.
> >For example:
> > <xsd:complexType>
> > <vsequence>
> > <xsd:simpleType>
> > </xsd:restriction>
> > </xsd:simpleType>
> > </xsd:element>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:element>
the
> >garbage collected.
objec
> >Thanks.
> >Robin Noble-Thomas
Previous Topic:Parsing Question
Next Topic:Parsing Question
Current Time: Mon Sep 01 01:20:37 EDT 2025
Powered by FUDForum. Page generated in 0.03878 seconds
