Does not reflect correct LogLevel in JBoss 5.1 [message #531361] |
Tue, 04 May 2010 15:18 |
Originally posted by: bit2oo.hotmail.com
We were running BIRT in JBoss 4.2.3 with setting "BIRT_VIEWER_LOG_LEVEL" to
"WARNING" in web.xml. But recently we moved application to JBoss 5.1 and
suddenly we start getting report log "ReportEngine_yyyy_mm_dd_hh_mm_ss.log"
with "FINE" level. I tried to set all level from "SEVERE " to "INFO" in
web.xml but I am always getting "FINE" level log as shown below. It stop
only for LEVEL= "OFF" .
Please suggest ... Here is the detail for log file.
May 4, 2010 1:23:41 AM org.eclipse.birt.report.engine.api.impl.ReportEngine
FINE: ReportEngine created. EngineConfig: EngineConfig:
PLATFORM_CONTEXT=org.eclipse.birt.core.framework.PlatformServletContext@70d332f4 ;webapplication.projectclasspath=;logLevel=SEVERE;org.eclips e.birt.report.engine.api.EngineConfig.emitterConfigs={html=org.eclipse.birt.report.engine.api.HTMLRenderOption@39b66b0a};BIRT_HOME=;logDest=E:\\birtlog;
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager
FINE: Start load extension point:
org.eclipse.birt.report.engine.reportitemGeneration
FINE: Load generation extension: Chart
FINE: Load generation extension: Crosstab
org.eclipse.birt.report.engine.reportitemPresentation
FINE: Load prsentation extension: Chart
org.eclipse.birt.report.engine.reportitemQuery
FINE: Load query extension: Chart
FINE: Load query extension: Crosstab
FINE: Start load extension point: org.eclipse.birt.report.engine.emitters
FINE: Load html emitter org.eclipse.birt.report.engine.emitter.html
FINE: Load pdf emitter org.eclipse.birt.report.engine.emitter.pdf
FINE: Load postscript emitter
org.eclipse.birt.report.engine.emitter.postscript
FINE: Load ppt emitter org.eclipse.birt.report.engine.emitter.ppt
FINE: Load xls emitter
org.eclipse.birt.report.engine.emitter.prototype.excel
FINE: Load doc emitter org.eclipse.birt.report.engine.emitter.word
May 4, 2010 1:23:42 AM org.eclipse.birt.report.engine.api.impl.ReportEngine
Re: Does not reflect correct LogLevel in JBoss 5.1 [message #531427 is a reply to message #531361] |
Tue, 04 May 2010 20:29 |
What version of BIRT are you using? I assume this is the WebViewer?
Jason
FUDForum. Page generated in 0.03039 seconds
