| Another one of those warnings... [message #53610] | Mon, 06 April 2009 10:01  |  |
| Eclipse User  |  |  |  |  | Another one of those warnings, that I would like to understand why they appear and what causes them:
 Classpath entry /<projectname>/lib/api_cs.jar will not be exported or published. Runtime ClassNotFoundExceptions may result.   <projectName>  P/<projectName> Classpath Dependency Validator Message
 This is in a plain vanilly Java project that has a couple of libraries sitting in ./lib and for each of them I get a warning as shown.
 Not sure, whether that has to do with the fact that this project also contains a MANIFEST.MF file since it's eventually wrapped up into a ..jar, but why does eclipse pester me with these "...not exported..." warnings?
 Michael
| Re: Another one of those warnings... [message #53763 is a reply to message #53636] | Mon, 06 April 2009 11:02  |  |
| Eclipse User  |  |  |  |  | Eric Rizzo wrote: > > ...
 > You can disable the Classpath Dependency validator; open the project
 > properties and select the Validation node.
 > I thought that particular validation was added only for Web Tools
 > projects, but perhaps my memory is faded on this...
 > Hope this helps,
 > Eric
 Thanks Eric, that helped indeed! It brought me onto the right track. For whatever - probably "historical" reasons - I had two more builders enabled, one called "Validation" only (and on which the "Remove" button was grayed out :-(  ), and another one, "JSP Validation" or something of that sort - don't recall any more).
 Since the former was unremovable, I went directly to the project files and removed everything but the Java builder and facet from it. Then I still had these warnings for a while until I realized, that I had to explicitly delete those warnings (and only if they reappear after a build they would still be valid). Found that a bit odd and inconvenient but now those warnings have indeed been beaten to death!
 Michael
| Re: Another one of those warnings... [message #594636 is a reply to message #53610] | Mon, 06 April 2009 10:19  |  |
| Eclipse User  |  |  |  |  | On 4/6/2009 10:01 AM, Michael Moser wrote: > Another one of those warnings, that I would like to understand why they appear and what causes them:
 > Classpath entry /<projectname>/lib/api_cs.jar will not be exported or published. Runtime ClassNotFoundExceptions may result.<projectName>   P/<projectName>  Classpath Dependency Validator Message
 Hope this helps,
 Eric
| Re: Another one of those warnings... [message #594694 is a reply to message #53636] | Mon, 06 April 2009 11:02  |  |
 > Hope this helps,
 > Eric
 Michael
FUDForum. Page generated in 0.07749 seconds
