Problems using EPF with CVS [message #53577] |
Thu, 11 September 2008 07:47 |
I tried to use EPF with a CVS as described in the "Using Eclipse Process
Framework Composer with a Version Control System" document on the EPF site.
I have the following issues:
When I Share my project in CVS and later check it out on another computer,
I end up with one directory containing the checked out CVS content at
$USER_HOME\EPF\workspace.150\, including all the CVS folders and another
copy of my library at \epf-composer-1.5\epf_practices, withhout the CVS
folders.
If I click on a folder in my Resources view, it references the non-cvs
version of the content at \epf-composer-1.5\epf_practices :(
How do get EPF to point to the CVS content version when I do a CVS check
out?
Is the secret the epf.ini file, with the -data and -defaultlibrary
settings?
Trying this config
-data
@user.home/EPF/workspace.150
-defaultlibrary
@user.home/EPF/workspace.150/myEPFLibrary
Didn't change anything...
The .project file contains
<name>EPF_Practices</name> reflected within EPF, but how do I configure the
projects shown in my resources view?
OK, from the Resources navigator I can create a new project - from CVS,
which checks out the project from CVS and adds it as a EPF project.
I then import a Library from this location. But then I get all kinds of
conflicts... just seems to overwrite my previous library!?
FUDForum. Page generated in 0.03539 seconds
