Home » Eclipse Projects » Eclipse Platform » Opening Java Editor from Double Click
Opening Java Editor from Double Click [message #53556] Thu, 29 May 2003 06:47 Go to next message
Hi, I have created a new view with a list of java classes that have errors
specific
to my plugin (not the Task View!) - I want to be able to double click on an
item
in my table list and it will open the relevant class in a Java editor. At
the moment
I double click and it brings up the Sample view of saying "double click
detected",
but thats about it!
Also on an aside - how can I underline text like the java editor does with
a red or green line underneath specific text?
Matt Hawkins
Re: Opening Java Editor from Double Click [message #53979 is a reply to message #53556] Thu, 29 May 2003 11:15 Go to previous messageGo to next message
Originally posted by: knut_radloff.oti.com
"Matthew P Hawkins" <hawkini_uk@uk.ibm.com> wrote in message news:bb4ofo$ojn$1@rogue.oti.com...
> specific
> item
See the org.eclipse.ui.actions.OpenFileAction and ResourceNavigator.handleOpen for an example of how to use it.
The Java editor draws the squiggly lines on top of the text widget. It uses the AnnotationPainter to render annotations (search
results, errors). See also PaintManager and IPainter. You should be able to use an annotation painter.
Perhaps someone else can give a brief overview of how annotations work?
Knut
Re: Opening Java Editor from Double Click [message #58750 is a reply to message #53979] Mon, 02 June 2003 06:11 Go to previous messageGo to next message
I've looked but I still do not understand what ResourceNavigator.handleOpen
does - it basically gets an ActionGroup (ResourceNavigator) and then
runs the defaultAction - which in ResourceNavigatorActionGroup is absolutely
nothing - and as for OpenFileAction that is completely wierd!
If anyone has some example code that they have specifically written for
their own view can they please give me a shout? Or alternatively if this
has been documented somewhere I would greatly appreciate a link :-)
Matt
"Knut Radloff" <knut_radloff@oti.com> wrote in message
news:bb587a$4hs$1@rogue.oti.com...
errors
> > specific
an
> > item
At
with
> Knut
Re: Opening Java Editor from Double Click [message #66051 is a reply to message #58750] Fri, 06 June 2003 19:09 Go to previous message
"Matthew P Hawkins" <hawkini_uk@uk.ibm.com> wrote in message news:bbf7th$a5i$1@rogue.oti.com...
defaultAction is first invoked on MainActionGroup from ResourceNavigator.handleOpen.
It ends up in OpenActionGroup.runDefaultAction which passes the current selection (your IFile that has errors) to the
OpenFileAction.
Look at the super and subclasses.
Knut
Previous Topic:Replacing options in 'File->New'
Next Topic:Working example of revealing a tree node
Current Time: Fri Jul 18 19:15:13 EDT 2025
Powered by FUDForum. Page generated in 0.02826 seconds
