TimeZone problem [message #530516] |
Thu, 29 April 2010 22:13 |
Elizabeth Messages: 13 Registered: December 2009 |
Junior Member |
I am trying to change the time zone that my BIRT Chart Engine is using after the chart has been created. My chart has DateTime across the x-axis. I have a list of org.eclipse.birt.chart.util .CDateTime that I'm using to populate the x-axis. To change the TimeZone, i'm trying to cycle through each CDateTime and change the timezone (CDateTime.setTimeZone(com.ibm.icu.util.TimeZone)). Upon doing this, I get the following error:
java.lang.LinkageError: loader constraint violation: when resolving method " org.eclipse.birt.chart.util.CDateTime.setTimeZone(Lcom/ibm/i cu/util/TimeZone;)V " the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, cse/rssm/gui/views/chart/signalchart/SignalChartManager, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/birt/chart/util/CDateTime, have different Class objects for the type com/ibm/icu/util/TimeZone used in the signature
If I set the default time zone (by TimeZone.setDefault(aTimeZone)) and then open the chart, everything works fine. If I change the time zone while the chart is open, close the chart, and then re-open the chart, it works just fine. However, I would like to refresh the chart, rather than having to close it and re-open it.
I have tried using several different versions of the icu4j jar, including 3.4.4, 3.4.5, and 4.2.1.1.
FUDForum. Page generated in 0.02956 seconds
