Home » Archived » M2M (model-to-model transformation) » [ATL]problem in something2XML transformation
[ATL]problem in something2XML transformation [message #53515] |
Thu, 19 July 2007 10:28  |
After I get target.ecore file from a transformation, for example,
source.ecore--->confirm to--->sourceMM.ecore
target.ecore--->confirm to--->targetMM.ecore
transformation file:source2target.atl
after this transformation, I get target.ecore like:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns="http://esit.hp.com/0.1/models/argumentsModel">
<OpcnodeArgu groupName="CTO" nodeName="www.ali88.com"
nodeLabel="www.ali88.com"
netType="VPN" machType="Windows XP" ipAddress="2.2.2.2"/>
</xmi:XMI>
Now I want to transform it to an XML file
xmlfile.ecore--->confirm to--->XMLMM.ecore
transformation file:target2xml.atl
My question is how to handle the namespace?
I want to put the [xmlns="http://esit.hp.com/0.1/models/argumentsModel"]
into the xmlfile.ecore.
However, after target2xml transformation, the xmlfile.ecore I get is:
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="XML">
<Root name="OpcnodeArgu">
<children xsi:type="Element" name="groupName">
<children xsi:type="Text" value="CTO"/>
</children>
<children xsi:type="Element" name="nodeName">
<children xsi:type="Text" value="www.ali88.com"/>
</children>
<children xsi:type="Element" name="nodeLabel">
</children>
<children xsi:type="Element" name="netType">
<children xsi:type="Text" value="VPN"/>
</children>
<children xsi:type="Element" name="machType">
<children xsi:type="Text" value="Windows XP"/>
</children>
<children xsi:type="Element" name="ipAddress">
<children xsi:type="Text" value="2.2.2.2"/>
</children>
</Root>
</children>
</children>
</children>
</children>
</children>
</children>
</Root>
</xmi:XMI>
As you see, xmlns="http://esit.hp.com/0.1/models/argumentsModel" is lost.
My question is how to keep
xmlns="http://esit.hp.com/0.1/models/argumentsModel" in the xmlfile.ecore
after target2xml transformation?
Re: [ATL]problem in something2XML transformation [message #54085 is a reply to message #53515] |
Fri, 20 July 2007 12:22   |
sfyu a écrit :
> xmlns:xmi="http://www.omg.org/XMI"
> </xmi:XMI>
> xmlns="XML">
> </children>
> </children>
> </children>
> </children>
> </children>
> </children>
> </Root>
> </children>
> </children>
> </children>
> </children>
> </children>
> </children>
> </Root>
> </xmi:XMI>
I think you are missing a step in your process : your output file is
still into xmi format, and you need to use the XML extraction to get the
correct xml file (AM3 perspective, then right-click on file, extract
XML model to XML file).
For the missing xmlns problem, you need to manually create (in the
target2xml transformation) a chidren under the root XML element.
William Piers
MDA Consultant, Obeo (http://www.obeo.fr)
Re: [ATL]problem in something2XML transformation [message #54192 is a reply to message #54085] |
Sun, 22 July 2007 08:45   |
Hi William,
Thanks for your help.
1) I omitted the XML extraction step in my previous post, so the output is
still in XMI format, but it does not matter.
2) Just as you mentioned, in order to keep the namespace information,I have
to manually create (in the target2xml transformation) a chidren wich value
"http://esit.hp.com/0.1/models/argumentsModel" under the root XML element.
But this solution does not sound good because I have to hard code the
namespace "http://esit.hp.com/0.1/models/argumentsModel" in the atl file. In
fact, the namespace information can be extracted from the source model file.
That is, the namespace has already existed in target.ecore, when I do
target2xml transformation, I'd better get the namespace from target.ecore
file and put it in xmlfile.ecore.
Is it possible to do that?
Stephen Yu.
"William Piers" <william.piers@obeo.fr> wrote in message
news:f7qnh1$33d$1@build.eclipse.org...
> sfyu a
Re: [ATL]problem in something2XML transformation [message #54270 is a reply to message #54192] |
Mon, 23 July 2007 05:00   |
I don't think it's possible to get the namespace information in the ATL
transformation. Hard coding the namespace in the transformation may be
the best solution for what you want to do.
But I don't understand why you want to put the targetMM namespace in the
output xml file. I explain :
- The target.ecore file conforms to the targetMM metamodel, so the xmi
file contains a reference to the metamodel (the namespace
"http://esit.hp.com/0.1/models/argumentsModel").
- When you create the xmlfile.ecore, it is conforming to the XML
metamodel, so the namespace becomes XML.
> Hi William,
> Stephen Yu.
>> sfyu a écrit :
>>> Hi,
>>> </xmi:XMI>
>>> xmlns="XML">
>>> </children>
>>> </children>
>>> </children>
>>> </children>
>>> </children>
>>> </children>
>>> </Root>
>>> </children>
>>> </children>
>>> </children>
>>> </children>
>>> </children>
>>> </children>
>>> </Root>
>>> </xmi:XMI>
>> I think you are missing a step in your process : your output file is still
>> into xmi format, and you need to use the XML extraction to get the correct
>> xml file (AM3 perspective, then right-click on file, extract XML model to
>> XML file).
>> Regards,
>> William Piers
Re: [ATL]problem in something2XML transformation [message #54324 is a reply to message #54270] |
Mon, 23 July 2007 05:24   |
I want to keep the targetMM namespace in the out xml file becaue JAXB
requires this. The out put xml file(after xml data extraction) is the
input of JAXB program which will unmarshall the xml data to a java object.
Stephen Yu.
William Piers wrote:
>> Hi William,
In
>> Stephen Yu.
>>> sfyu a écrit :
>>>> Hi,
>>>> </xmi:XMI>
>>>> xmlns="XML">
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </Root>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </children>
>>>> </Root>
>>>> </xmi:XMI>
>>> Hi,
>>> XML file).
>>> Regards,
>>> William Piers
Re: [ATL]problem in something2XML transformation [message #54933 is a reply to message #54324] |
Thu, 26 July 2007 08:21  |
Firstly, I understand that JAXB needs a specific namespace URI. However,
I do not believe that this URI should be the same as the one used for
the metamodel: the XMI file and the actual JAXB files do not have the
same schema.
Secondly, if you do not want to hardcode the namespace URI in your
transformation, you may provide it in one of the source models. One
possibility would be to add an additional "configuration" source models
containing such information.
Frédéric Jouault
Stephen Yu wrote:
> Stephen Yu.
>> ATL transformation. Hard coding the namespace in the transformation
>> may be the best solution for what you want to do.
>> the output xml file. I explain :
>>> Hi William,
>>> output is still in XMI format, but it does not matter.
>>> information,I have to manually create (in the target2xml
>>> element.
>>> file.
> In
>>> model file.
>>> target.ecore file and put it in xmlfile.ecore.
>>> Stephen Yu.
>>>> sfyu a écrit :
>>>>> Hi,
>>>>> </xmi:XMI>
>>>>> I want to put the
>>>>> [xmlns="http://esit.hp.com/0.1/models/argumentsModel"] into the
>>>>> xmlfile.ecore.
>>>>> xmlns="XML">
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </Root>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </children>
>>>>> </Root>
>>>>> </xmi:XMI>
>>>>> lost.
>>>>> xmlfile.ecore after target2xml transformation?
>>>> Hi,
>>>> the correct xml file (AM3 perspective, then right-click on file,
>>>> extract XML model to XML file).
>>>> Regards,
>>>> William Piers
Current Time: Sun Jul 13 16:58:10 EDT 2025
Powered by FUDForum. Page generated in 0.04178 seconds
