Home » Modeling » GMF (Graphical Modeling Framework) » Can't get XSD to work
Can't get XSD to work [message #53489] Fri, 22 September 2006 06:37 Go to next message
I want to be able to use XSD for development. But I can't get it to work.
I've downloaded the XSD zip and unzipped it in my eclipse folder so
everything I need should be there?
I've added to the build path within a gmf project:
org.eclipse.emf.mapping.xsd2ecore.editor
org.eclipse.xsd.ecore.exporter
org.eclipse.xsd.ecore.importer
org.eclipse.xsd.edit
org.eclipse.xsd.editor
org.eclipse.xsd
I've then added a xsd file (from an example) but it just registers it as a
text file...
Could someone point me to some good docs or tell me what I'm doing wrong.
Cheers
Re: Can't get XSD to work [message #53516 is a reply to message #53489] Fri, 22 September 2006 07:00 Go to previous messageGo to next message
Hi Gaff,
try downloading the xsd-plugin from the calisto-update-site via the
Eclipse-update-feature(Help ->Software updates->find and install
->search for new features..).
Maybe you missed something during manual installation.
Greets Alex
> work. I've downloaded the XSD zip and unzipped it in my eclipse folder
> so everything I need should be there?
> org.eclipse.xsd
> a text file...
> Cheers
Re: Can't get XSD to work [message #53648 is a reply to message #53489] Fri, 22 September 2006 07:40 Go to previous messageGo to next message
Gaff,
Did you run eclipse.exe -clean to update the configuration after
unzipping the plugins?
> org.eclipse.xsd
> as a text file...
> Cheers
Re: Can't get XSD to work [message #53701 is a reply to message #53516] Fri, 22 September 2006 08:23 Go to previous messageGo to next message
Can't see individual files form Callisto.
Got everything from gmf modelling there.
Then total .zip from XSD download.
Pretty sure I have everything.
Maybe I just don't know how to use software properly but am pretty sure
a.xsd file would show up differenttly than just a text file. Am I right.
Note, that this example is the mindmap one from tutorial.
Tried using the mindmap.ecore file but that just shows up as having
errors, am looking through gmf group for solution to this:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1$Diagno sticWrappedException:
org.xml.sax.SAXParseException: The processing instruction target matching
"[xX][mM][lL]" is not allowed.
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:307)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268).....
Re: Can't get XSD to work [message #53725 is a reply to message #53648] Fri, 22 September 2006 08:23 Go to previous messageGo to next message
Tried this, didn't work.
Re: Can't get XSD to work [message #53856 is a reply to message #53725] Fri, 22 September 2006 08:54 Go to previous messageGo to next message
Con,
Have you looked in the Error log for potential source of problems?
Re: Can't get XSD to work [message #53922 is a reply to message #53701] Fri, 22 September 2006 08:57 Go to previous message
Con,
If you've installed XSD and there is no Open With -> Sample XML Schema
Editor on the popup menu for a .xsd file, then Eclipse does not think
you've installed XSD properly. The error log should provide
information to help indicate what might be wrong or missing. The
problem below is a basic error thrown by the SAX parser and indicates
that there is something not quite right about the XML itself...
> sure a.xsd file would show up differenttly than just a text file. Am I
> right.
> matching "[xX][mM][lL]" is not allowed.
> at
> at
Previous Topic:Link Constraint with Java Expression causes Exception
Next Topic:Label text for EDatatType values
Current Time: Sun Nov 02 16:22:28 EST 2025
Powered by FUDForum. Page generated in 0.56309 seconds
