Home » Modeling » TMF (Xtext) » DSL project creation - extention points?
DSL project creation - extention points? [message #53471] Sat, 27 June 2009 13:04 Go to next message
When creating a new DSL, I find that there are a few tasks I often:
Sometimes I've been writing helper classes or Xtend files to decorate my
metamodel with behaviour. Sometimes I just do it to shield myself from
changes to the model (helper functions to navigate around the model - if
the model structure changes the helper functions have to, but none of the
users have to).
Another thing would be to be able to have a "Create transformer project"
tickbox on the project creation page - which would do something similar
to "Create generator project", but would give me a new project with an MWE
file and .ext file with an example of the workflow (which I find myself
cut'n'pasting from existing m2m transformations). Actually, I don't even
need the tickbox - if I could have it happen every time, it would be easy
to delete it when I don't want one.
These sorts of thing (and probably others) are specific to me - other
people might not want them, and you wouldn't want to bloat your new
project set with stuff they don't use.
So - I'm wondering if there's a nice easy way to hook into the actual
creation of the project(s) when completing the New XText Project wizard.
I would expect to either be able to create new files in the projects
directly, and perhaps be able to influence the eclipse plugin dependencies.
I suspect with my knowledge of eclipse (mmm - average-ish), I could cobble
something together, reusing and extending your components, to add the
features I want (perhaps by creating a new New Project Wizard at the top
level). But it occurs to me that you've probably already got some nice
extention points I could use to make this easier.
Re: DSL project creation - extention points? [message #53635 is a reply to message #53471] Sat, 27 June 2009 15:16 Go to previous messageGo to next message
Hi Antony,
to make it short: I'm afraid that such an extension mechanism does not
exist.
Some of your use cases are good candidates for generator fragments (e.g.
create stubs for transformations), others are not (e.g. adding new
projects to your workspace). Maybe you want to file a bugzilla for an
extension point for the Xtext project wizard, that will allow clients to
add new pages to the wizard?
Sebastian
Am 27.06.2009 19:04 Uhr, schrieb Antony Wilkins:
> the users have to).
> MWE file and .ext file with an example of the workflow (which I find
> myself cut'n'pasting from existing m2m transformations). Actually, I
> don't even need the tickbox - if I could have it happen every time, it
> would be easy to delete it when I don't want one.
> cobble something together, reusing and extending your components, to add
> the features I want (perhaps by creating a new New Project Wizard at the
> top level). But it occurs to me that you've probably already got some
> nice extention points I could use to make this easier.
Re: DSL project creation - extention points? [message #53686 is a reply to message #53635] Sat, 27 June 2009 17:29 Go to previous messageGo to next message
I see - so for the former I would write a GeneratorFragment class and just
paste it in manually? That seems reasonable, because I don't want them
for every new project - I will want to decide on a case by case basis.
Actually I should have realised this one for myself - I've been running
MWE files with GeneratorFragment class names visible in the XML! Doh!
For the latter - I'll raise that bugzilla.
Thanks again for your help :)
Antony
Sebastian Zarnekow wrote:
> Hi Antony,
> exist.
> Sebastian
>> the users have to).
Re: DSL project creation - extention points? [message #53735 is a reply to message #53686] Sat, 27 June 2009 17:49 Go to previous message
(raised bugzilla 281754)
Previous Topic:Recursive Definitions in xtext
Next Topic:debugging DSL serialisation
Current Time: Sun Aug 31 02:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.02718 seconds
