Java code reformatting question [message #53459] |
Wed, 30 April 2003 11:43  |
Originally posted by: no.email.please.com
[Is eclipse.technology the right newsgroup for this kind of question?
How come there is no "eclipse.jdt" newsgroup?]
When I format (Ctrl-Shift-f) my code, the following:
new Foo("abc", "def", "ghi")
is turned into
new Foo(
"abc",
"def",
"ghi"
.... which I don't like very much. I'd rather have something a little bit
more space efficient.
I looked at the Code formatter options but I didn't see where this is
defined. Can Eclipse do that or do I need to install a plug-in? (does
Jalopy support this kind of customization?)
Cedric
http://beust.com/weblog
Re: Java code reformatting question [message #53564 is a reply to message #53459] |
Thu, 01 May 2003 09:55  |
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
That only happens when the line is longer than the max line length.
You can increase this value in Window-> Preferences,
Java->Code formatter: tab Line splitting.
> Cedric
Re: Java code reformatting question [message #593391 is a reply to message #53459] |
Wed, 30 April 2003 11:47  |
Cedric, I would repost to eclipse.tools.jdt
Darins
"Cedric Beust" <no.email@please.com> wrote in message
news:Xns936D58EA977A0noemailpleasecom@204.138.98.10...
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
> Cedric
Re: Java code reformatting question [message #593411 is a reply to message #53459] |
Wed, 30 April 2003 12:08  |
This newsgroup is deprecated.
See eclipse.tools.jdt
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
Not yet. I think Jalopy does support this.
Randy
Re: Java code reformatting question [message #593428 is a reply to message #53459] |
Wed, 30 April 2003 12:31  |
On Wed, 30 Apr 2003 15:43:43 +0000 (UTC), Cedric Beust
Hi Cedric,
eclipse.jdt is more appropriate for java code formatter question. This
kind of settings is in the works for the new formatter. We plan to
completely change the actual formatter. There are simply too many
problems and the one you have is just one of them :-(.
The solution for now is to use another formatter like Jalopy.
Olivier
Re: Java code reformatting question [message #593441 is a reply to message #53459] |
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
> Cedric
FUDForum. Page generated in 0.06170 seconds
