Home » Archived » BIRT » Set data set programatically(Setting dataset in program)
Set data set programatically [message #529419] Sun, 25 April 2010 01:04 Go to next message
I am creating charts dynamically.I am setting data set as follows.
ElementFactory ef = designHandle.getElementFactory( );
ExtendedItemHandle extendedItemHandle =
ef.newExtendedItem( null, "Chart" );
try{
extendedItemHandle.getReportItem( ).setProperty( "chart.instance",newChart );
} catch( ExtendedElementException e )
e.printStackTrace( );
// Get an ODA data set and bind it to the chart
OdaDataSetHandle dataSet = ( OdaDataSetHandle )
designHandle.getDataSets( ).get( 0 );
try {
extendedItemHandle.setDataSet( dataSet );
extendedItemHandle.setHeight( "250pt" );
extendedItemHandle.setWidth( "400pt" );
} catch ( SemanticException e ) {
But when i open the saved rptdesign file in birt (->Edit chart)i am getting the following error
" Column binding "row["Year"]" has referred to a binding "Year" which does not exist."
It is not setting dataset properly.
can anybody send proper setting of data set programatically.
Thank You,
Laxmipathi raju
Re: Set data set programatically [message #529642 is a reply to message #529419] Mon, 26 April 2010 11:31 Go to previous message
You have to create the bindings on the chart. This is the mapping to
the dataset.
ExtendedItemHandle eih = designFactory.newExtendedItem (
null,"Chart" );
ComputedColumn cs1=null, cs2=null;
try
eih.setHeight( "175pt" );//$NON-NLS-1$
eih.setWidth( "450pt" );//$NON-NLS-1$
eih.setProperty ( ExtendedItemHandle.DATA_SET_PROP,
"ChartData");//$NON-NLS-1$
eih.setProperty("outputFormat", "PNG");
PropertyHandle cs = eih.getColumnBindings();
cs1 = StructureFactory.createComputedColumn();
cs2 = StructureFactory.createComputedColumn();
cs1.setName("xaxis");
cs1.setDataType("string");
cs2.setName("yaxis");
cs2.setDataType("float");
cs1.setExpression("dataSetRow[\"xaxis\"]");
cs2.setExpression("dataSetRow[\"yaxis\"]");
cs.addItem(cs1);
cs.addItem(cs2);
Jason
On 4/25/2010 1:05 AM, laxmipathi raju wrote:
> try{
> try {
> does not exist."
> Thank You,
> Laxmipathi raju
Previous Topic:To load the report in the same page
Next Topic:OSX cocoa PDF print and save not functioning from within WebViewer
Current Time: Sun Jul 13 15:59:53 EDT 2025
Powered by FUDForum. Page generated in 0.03486 seconds
