Home » Eclipse Projects » GEF » PrintBigFigureOperation
PrintBigFigureOperation [message #53366] Fri, 10 January 2003 09:16 Go to next message
Originally posted by: sven.e-sven.net
Already posted it in another thread. I'd like to get some feedback on
it. I think the translating of the figure and it's childs is not the
best way to do this, but it works.
Sven\ 8)
PS: The Question Window in the run method doesn't belong there. Is there
a way to display the number of pages in the PrintDialog?
import java.util.List;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.PrintFigureOperation;
import org.eclipse.draw2d.PrinterGraphics;
import org.eclipse.draw2d.geometry.Point;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.swt.printing.Printer;
import org.eclipse.ui.PlatformUI;
* Druckt eine IFigure über mehrere Seiten.
* @author Sven Müller
public class PrintBigFigureOperation extends PrintFigureOperation {
private double scale;
public PrintBigFigureOperation(Printer printer, IFigure figure) {
super(printer, figure);
scale = getPrinter().getDPI().x / Display.getDefault().getDPI().x;
* @see org.eclipse.draw2d.PrintOperation#printPages()
protected void printPages() {
IFigure figure = getPrintSource();
boolean nextPage = true;
Point offset = figure.getBounds().getLocation().getCopy();
int x =
(int) (figure.getBounds().getSize().width
/ (getPrintRegion().width / scale));
int y =
(int) (figure.getBounds().getSize().height
/ (getPrintRegion().height / scale));
int memX1 = x;
int memX2 = offset.x;
PrinterGraphics g = getFreshPrinterGraphics();
List childs = figure.getChildren();
while (nextPage) {
g.pushState();
getPrinter().startPage();
g.setForegroundColor(figure.getForegroundColor());
g.setBackgroundColor(figure.getBackgroundColor());
g.setFont(figure.getFont());
g.scale(scale);
figure.translate(offset.x, offset.y);
for (int i = 0; i < childs.size(); i++)
((IFigure) childs.get(i)).translate(-offset.x, -offset.y);
g.translate(figure.getBounds().getLocation().getCopy().negat e());
g.clipRect(figure.getBounds());
figure.paint(g);
getPrinter().endPage();
g.restoreState();
if (x > 0) {
x--;
offset.x = (int) (getPrintRegion().width / scale);
} else if (y > 0) {
y--;
x = memX1;
figure.translate(-x * offset.x, 0);
((IFigure) childs.get(i)).translate(x * offset.x, 0);
offset.x = memX2;
offset.y = (int) (getPrintRegion().height / scale);
} else {
nextPage = false;
* @see org.eclipse.draw2d.PrintOperation#run(String)
public void run(String jobName) {
if (MessageDialog
.openQuestion(
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l(),
"Question...",
"Really print "
+ getNumofPages()
+ " pages on "
+ getPrinter().getPrinterData().name
super.run(jobName);
private int getNumofPages() {
double x =
getPrintSource().getBounds().getSize().width
/ (getPrintRegion().width / scale);
double y =
getPrintSource().getBounds().getSize().height
/ (getPrintRegion().height / scale);
return (int)
(((x > (int) x) ? (int) x + 1 : (int) x)
* ((y > (int) y) ? (int) y + 1 : (int) y));
Re: PrintBigFigureOperation [message #53473 is a reply to message #53366] Fri, 10 January 2003 10:13 Go to previous messageGo to next message
Originally posted by: noone.ibm.com
Thank you Sven, this is looking good.
Is it necessary to translate the figure at all? I think Randy's strategy
that he explained yesterday may be the best way to go. Idenitfy how many
pages will need to be printed, identify where these pages "start", and
translate the PrinterGraphics object to these points.
Re: PrintBigFigureOperation [message #53499 is a reply to message #53473] Fri, 10 January 2003 11:11 Go to previous message
You are right it's easier and faster to simply translate the PG.
Why move the world beneath your feet if walking is so easy? ;)
Sven\ 8)
Here's a better impl.:
Point offset = figure.getBounds().getLocation();
int x =
(int) (getPrintSource().getBounds().getSize().width
int y =
(int) (getPrintSource().getBounds().getSize().height
for (int i = 0; i < getNumofPages(); i++) {
g.pushState();
g.scale(scale);
g.translate(-offset.x, -offset.y);
figure.paint(g);
g.restoreState();
if (x > 0) {
x--;
offset.x += (int) (getPrintRegion().width / scale);
} else if (y > 0) {
y--;
offset.y += (int) (getPrintRegion().height / scale);
offset.x = figure.getBounds().getLocation().x;
x =
if (MessageDialog
.openQuestion(
"Question...",
"Really print "
+ getNumofPages()
+ " pages on "
super.run(jobName);
* Berechnet die Seiten die nötig sind um die {@link IFigure IFigure}
auf dem gewählten {@link Printer Printer} auszugeben
* @return int
double x =
double y =
return ((x > (int) x) ? (int) x + 1 : (int) x)
* ((y > (int) y) ? (int) y + 1 : (int) y);
Previous Topic:How can i support IPropertySource in GEF?
Next Topic:help me please
Current Time: Tue Jul 22 01:48:45 EDT 2025
Powered by FUDForum. Page generated in 0.27675 seconds
