Home » Archived » EPF » Databinding and rich text editor
Databinding and rich text editor [message #53364] Tue, 09 September 2008 03:12 Go to next message
Originally posted by: mcervera.integranova.com
Hi.
I am trying to use databinding with the rich text editor. I've managed
to make it work by simply returning an instance of
RichTextObservableValue the same way observeText returns
TextObservableValue. RichTextObservableValue is a class I've implemented
which inherites from AbstractVetoableValue. Everything is ok but I have
problems with the modify listener, that is, the ModifyEvent is not fired
when I write in the RichTextEditor, therefore my editor is not set as
dirty. To my surprise, this event is fired when pressing keys like
delete, back space... but not when I press simple characters. I don't
understand what is going on. Has anyone experienced anything similar?
Has anyone got to make databinding work with this editor?
Thanks in advance.
Mario
Re: Databinding and rich text editor [message #53392 is a reply to message #53364] Tue, 09 September 2008 16:34 Go to previous messageGo to next message
Mario Cervera wrote:
> Hi.
We use a custom RichTextObservableValue and it works correctly on
Eclipse 3.3. I have not yet started testing our stuff on 3.4, however.
The class is in this package:
< https://www.skywayperspectives.org/fisheye/browse/CVS_OpenSo urce/skyway/common/plugins/org.skyway.ui/src/org/skyway/ui/r ichtext>
Hope this helps,
Eric
Re: Databinding and rich text editor [message #53470 is a reply to message #53392] Wed, 10 September 2008 03:03 Go to previous messageGo to next message
Hi Eric,
that's the class I'm using but the method modifyText is not invoked as
much as I'd like to. It's strange but it's invoked when I either use the
toolbar or press Del, back space... but not when I write simple
characters :S. The problem of this is that I have problems to set my
model as dirty. I could use the focus out event but the listener I use
doesn't get called either.
Mario
>> Hi.
>> implemented which inherites from AbstractVetoableValue. Everything is
>> ok but I have problems with the modify listener, that is, the
>> ModifyEvent is not fired when I write in the RichTextEditor, therefore
>> my editor is not set as dirty. To my surprise, this event is fired
>> when pressing keys like delete, back space... but not when I press
>> simple characters. I don't understand what is going on. Has anyone
>> experienced anything similar? Has anyone got to make databinding work
>> with this editor?
> Hope this helps,
> Eric
Re: Databinding and rich text editor [message #53497 is a reply to message #53470] Wed, 10 September 2008 09:41 Go to previous messageGo to next message
> Hi Eric,
> model as dirty.
Are you trying it on Eclipse 3.4? I know our class works on 3.3 - we get
modify events as expected.
Eric
>>> Hi.
>>> managed to make it work by simply returning an instance of
>>> therefore my editor is not set as dirty. To my surprise, this event
>>> is fired when pressing keys like delete, back space... but not when I
>>> press simple characters. I don't understand what is going on. Has
>>> anyone experienced anything similar? Has anyone got to make
>> Hope this helps,
>> Eric
Re: Databinding and rich text editor [message #53524 is a reply to message #53497] Wed, 10 September 2008 10:19 Go to previous messageGo to next message
Yes I am using eclipse 3.4.0, maybe that's the reason :(
>> Hi Eric,
>> the toolbar or press Del, back space... but not when I write simple
>> model as dirty.
> Eric
>>>> Hi.
>>>> is ok but I have problems with the modify listener, that is, the
>>>> I press simple characters. I don't understand what is going on. Has
>>> Hope this helps,
>>> Eric
Re: Databinding and rich text editor [message #485886 is a reply to message #53524] Tue, 15 September 2009 08:49 Go to previous messageGo to next message
Hello
I'm using Eclipse 3.5.0 having the same problem, the ModifyListener is not
notified after text was tipped.
Was there any work done on this issue? Does a bug report exists? Should I
report one? Is there a workaround available?
greets
Flavio
>>> Hi Eric,
>>> model as dirty.
>> Eric
>>>>> Hi.
>>>> Hope this helps,
>>>> Eric
Re: Databinding and rich text editor [message #485942 is a reply to message #53524] Tue, 15 September 2009 11:18 Go to previous messageGo to next message
hello
I kind of patched the "rte.js" and it kind of works now :-).
One strange behavior, the first key tip is not forwarded as modify event
and
some modify events will now probably be fired twice, but I don't care :-).
But here part of the org.eclipse.epf.richtext_1.5.0.x/rte/rte.js script:
var excludeModify = new Array(16, KEY_ARROW_DOWN, KEY_ARROW_LEFT,
KEY_ARROW_RIGHT, KEY_ARROW_UP, KEY_END, KEY_HOME, KEY_PAGE_DOWN,
KEY_PAGE_UP, KEY_TAB);
// Handles the key events.
function keyPressed(event) {
var keyCode = event.keyCode;
if (keyCode == 0 && !document.all) {
keyCode = event.charCode;
switch (keyCode) {
case 99:
keyCode = KEY_C;
break;
case 102:
keyCode = KEY_F;
break;
case 115:
keyCode = KEY_S;
break;
case 118:
keyCode = KEY_V;
break;
case 120:
keyCode = KEY_X;
break;
case 122:
keyCode = KEY_Z;
break;
var ctrlKey = event.ctrlKey;
var shiftKey = event.shiftKey;
var altKey = event.altKey;
if ( !ctrlKey && !altKey ) {
var modified = true;
for (var i = 0; i < excludeModify.length; i++ ) {
if ( keyCode == excludeModify[i] ) {
modified = false;
if ( modified == true ) {
setStatus(STATUS_MODIFIED, keyCode);
Maybe this can be a starting point to resolve this issue?
Re: Databinding and rich text editor [message #506473 is a reply to message #485942] Thu, 07 January 2010 11:23 Go to previous messageGo to next message
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=265664
for more information on this issue
Re: Databinding and rich text editor [message #590448 is a reply to message #53364] Tue, 09 September 2008 16:34 Go to previous messageGo to next message
> Hi.
Hope this helps,
Eric
Re: Databinding and rich text editor [message #590493 is a reply to message #53392] Wed, 10 September 2008 03:03 Go to previous messageGo to next message
Hi Eric,
Mario
>> Hi.
>> with this editor?
> Hope this helps,
> Eric
Re: Databinding and rich text editor [message #590519 is a reply to message #53470] Wed, 10 September 2008 09:41 Go to previous messageGo to next message
> Hi Eric,
> model as dirty.
Eric
>>> Hi.
>> Hope this helps,
>> Eric
Re: Databinding and rich text editor [message #590546 is a reply to message #53497] Wed, 10 September 2008 10:19 Go to previous messageGo to next message
>> Hi Eric,
>> model as dirty.
> Eric
>>>> Hi.
>>> Hope this helps,
>>> Eric
Re: Databinding and rich text editor [message #598854 is a reply to message #53524] Tue, 15 September 2009 08:49 Go to previous messageGo to next message
Hello
greets
Flavio
>>> Hi Eric,
>>> model as dirty.
>> Eric
>>>>> Hi.
>>>> Hope this helps,
>>>> Eric
Re: Databinding and rich text editor [message #598863 is a reply to message #53524] Tue, 15 September 2009 11:18 Go to previous messageGo to next message
hello
and
switch (keyCode) {
case 99:
keyCode = KEY_C;
break;
case 102:
keyCode = KEY_F;
break;
case 115:
keyCode = KEY_S;
break;
case 118:
keyCode = KEY_V;
break;
case 120:
keyCode = KEY_X;
break;
case 122:
keyCode = KEY_Z;
break;
modified = false;
Re: Databinding and rich text editor [message #599047 is a reply to message #485942] Thu, 07 January 2010 11:23 Go to previous message
Previous Topic:Creating projects programmatically (how to use API)
Next Topic:EPF Composer - Activity Diagram Editor fail to open
Current Time: Wed Jul 16 19:59:07 EDT 2025
Powered by FUDForum. Page generated in 0.11402 seconds
