Home » Modeling » TMF (Xtext) » Xtext from Modelling package issues
Xtext from Modelling package issues [message #53363] Fri, 26 June 2009 17:22 Go to next message
So I downloaded the Galileo modelling GA package and:
- there is no documentation for Xtext, Xpand
- documentation for MWE is not working
- there are some examples (I can see FowlerDSL, EcoreDSL in
Preferences), but there is no UI to create them
- UI file creation contribution for new languages is not generated?
- there is "bad" icon for .xtext and .mwe files
- there is no outline for MWE
- outline is empty for xtend and xpand
- there is strange little bug. Sometimes when there had been an syntax
error in grammar, but it was corrected and code has no errors - there is
still red underline that did not disappeared. The code is correct, it
can be saved, edited in some other places, but the underline stays.
It will disappear after I edit the code exactly before the underlined
code. It happens quite often. (I use ANTLR)
Same issues with distro from Itemis, but documentation is ok there.
I guess that all those issues are well known? Or should I find a way to
reproduce the "underline" problem?
Krzysztof Kowalczyk
Re: Xtext from Modelling package issues [message #53501 is a reply to message #53363] Sat, 27 June 2009 14:30 Go to previous messageGo to next message
Hi Krzysztof,
thanks for detailed report. Some of the issues (see below) have already
been adressed and a fixed version is available in the itemis Xtext
distribution - as you already mentioned.
Am 26.06.2009 23:22 Uhr, schrieb Krzysztof Kowalczyk:
Fixed.
Fixed.
This is a known issues which has not been adressed so far.
Please file a bugzilla, as this is an enhancement request. However, we
have a similar ticket. https://bugs.eclipse.org/bugs/show_bug.cgi?id=281214
What is a "bad" icon?
Please file a ticket.
Already fixed.
This is a known issue. However, it is not reliably reproducable. Please
file a ticket, so it doesn't get lost.
That whould be great :-)
> Krzysztof Kowalczyk
Thanks again for the report,
Sebastian
Re: Xtext from Modelling package issues [message #54331 is a reply to message #53501] Tue, 30 June 2009 19:31 Go to previous messageGo to next message
Sebastian Zarnekow pisze:
Icon that look like property file icon not like an Xtext or Workflow icon ;)
How to reproduce "underline error".
So the general theme is to create a code and introduce an error that
will be displayed after the place that lead to the error. Then remove
the cause.
I am using xtext sample project "org.xtext.example.mydsl" without any
changes. Itemis distro is used, so that infer ANTLR.
Create sample project, run workflow, run Eclipse instance.
Create mydsl:
<code>
type String
type Int
entity One
entity Two{
</code>
code has error on line 6 as '{' is missing.
So we can add '{':
<code>
type String
type Int
entity One{
entity Two{
</code>
then there is no error in grammar but the '}' is still underlined.
I can change code before and after entity One and the underline is still
there:
<code>
type String
type Int
type NewType
entity OneOneOneOneOne{
entity Two{
property Prop :OneOneOneOneOne
</code>
If I change something inside entity One(after '{' and before '}') then
the underline disappear.
One can create another underline error by inserting and then removing
'{' after 'property Prop :OneOneOneOneOne'.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282086
Krzysztof Kowalczyk
Re: Xtext from Modelling package issues [message #54358 is a reply to message #54331] Wed, 01 July 2009 02:36 Go to previous message
Hi Krzysztof,
thanks for the detailed bug report.
Hopefully we can reproduce it, as we also saw this problem sometimes
(very seldom) but than never were able to reproduce it.
Sven
> icon ;)
>> Please file a ticket, so it doesn't get lost.
> the cause.
> Create mydsl:
> <code>
> type String
> type Int
> entity One
> entity Two{
> </code>
> So we can add '{':
> <code>
> type String
> type Int
> entity One{
> entity Two{
> </code>
> there:
> <code>
> type String
> type Int
> type NewType
> entity Two{
> </code>
> Krzysztof Kowalczyk
Previous Topic:Workflow for GMF editor model
Next Topic:[Xtext] Problem with Rules without Model Elements
Current Time: Thu Jul 17 19:21:22 EDT 2025
Powered by FUDForum. Page generated in 0.04987 seconds
