Re: Dynamic Parameter & Drill Through [message #528534 is a reply to message #528443] |
Tue, 20 April 2010 20:21 |
If articles parameter is multiselect it should come through the url like:
&articles=1348&articles=2545
Jason
tobias.koehler1987@googlemail.com wrote:
> I have a report which gets a dynamic list of Integers. This List is also
> needed in the subreport. In order to access the Parameter I added a new
> parameter to the subreport having the same data type.
> However, this is not working - when I start the Report via web viewer
> ( http://localhost:8080/birtviewer/run?__report=C%3A\app\REPOR TS\rpt.rptdesign&startDate=20.04.2009&endDate=20.04. 2010&articles=1348,2545&customers=5234)
> - I get the following Error:
> org.eclipse.birt.chart.exception.ChartException: The trigger data is
> invalid or its type is unknown.
> at org.eclipse.birt.chart.internal.datafeed.UserDataSetProcesso
> r.populate(UserDataSetProcessor.java:102)
> at org.eclipse.birt.chart.internal.datafeed.DataProcessor.fillS
> eriesDataSet(DataProcessor.java:1354)
> at org.eclipse.birt.chart.internal.datafeed.DataProcessor.gener
> ateRuntimeSeries(DataProcessor.java:811)
> ateRuntimeSeries(DataProcessor.java:1446)
> If I remove the articles parameter passthrough when hyperlinking the
> drill through function I can open the report without problems.
FUDForum. Page generated in 0.02894 seconds
