GUI Playback fails on Linux ("Cannot create master named pipe") [message #53359] |
Thu, 09 February 2006 06:15  |
--------------010508050203020709000804
I have a testsuite of automated GUI tests that I run sucessfully on
Windows using TPTP and the Automated GUI Recorder. However, when I try
to run the same testsuite on Linux, it fails to control the spawned
Eclipse process. Eclipse launches and displays the main window, but no
actions are replayed. After a about 5 minutes the test times out and
kills the spawned Eclipse process.
The following line is the only error that appears in the file
servicelog.log. Seems to be a resonable cause:
"Cannot create master named pipe: ramaster. Make sure the named pipe is
free and no other Agent Controller is using the same named pipe."
(the entire log file is atttached to this messgae)
Any ideas of how to resolve this problem?
My setup consists of the following parts:
Linux (Fedora Core 3)
Eclipse SDK 3.1 (linux-gtk)
TPTP Runtime 4.1.0
Automated GUI Recorder 4.1.0
EMF SDK 2.1
XSD SDK 2.1
JRE 5.0
Agent Controller Runtime 4.1.0 (linux-ia32)
/Hampus Edvardsson
name="servicelog.log"
Content-Disposition: inline;
filename="servicelog.log"
<CommonBaseEvent creationTime="2006-02-09T10:29:24.561595Z" globalInstanceId="A3EB1984000891894E0300F4088B90FE" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="10.0.0.140" locationType="IPV4" processId="7173" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.969788Z" globalInstanceId="A3EB1984000ECC2C0A9B693B3D1A2B5C" msg="Start processing plugin: org.eclipse.hyades.test.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.978724Z" globalInstanceId="A3EB1984000EEF1941DC194939845790" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="10.0.0.140" locationType="IPV4" processId="7173" subComponent="framework/RAServerConfig/RAServerConfigHandler2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.979017Z" globalInstanceId="A3EB1984000EF042797F3BC91DCA25F2" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.979135Z" globalInstanceId="A3EB1984000EF0B97D90B5E367ACF0C3" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.981120Z" globalInstanceId="A3EB1984000EF8781B9279851E59B21F" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.execution_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.981222Z" globalInstanceId="A3EB1984000EF8E16C1A5B8F79B42BF1" msg="Recovery: succeeded" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.981309Z" globalInstanceId="A3EB1984000EF9385EFA59096F3FE87F" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.981574Z" globalInstanceId="A3EB1984000EFA3E0C3738C321ACF1B2" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.981666Z" globalInstanceId="A3EB1984000EFA9C6E6F28D6529DC3D9" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.983236Z" globalInstanceId="A3EB1984000F00BD38B546923BA99855" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.983353Z" globalInstanceId="A3EB1984000F013304B9B394517D9526" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.983434Z" globalInstanceId="A3EB1984000F01844D8AFBCA2B0AE002" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.983528Z" globalInstanceId="A3EB1984000F01E36993667668D16E40" msg="Plugin org.eclipse.hyades.execution_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.983961Z" globalInstanceId="A3EB1984000F03926E06DF1D46C4566F" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.core_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984050Z" globalInstanceId="A3EB1984000F03ED119F3BBC4B254D28" msg="Recovery: succeeded" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984313Z" globalInstanceId="A3EB1984000F04F233D0CA7704E0FC3B" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.test.core_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984438Z" globalInstanceId="A3EB1984000F0570594F8B52323C71F4" msg="Finished processing plugin: org.eclipse.hyades.test.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984529Z" globalInstanceId="A3EB1984000F05CB7612D16E5926A5EA" msg="Start processing plugin: org.eclipse.hyades.execution_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984607Z" globalInstanceId="A3EB1984000F061A606D0396379DE953" msg="Plugin org.eclipse.hyades.execution_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984683Z" globalInstanceId="A3EB1984000F06664A4CDCD87FE4327E" msg="Finished processing plugin: org.eclipse.hyades.execution_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984760Z" globalInstanceId="A3EB1984000F06B323B52C37530AF5BE" msg="Start processing plugin: org.eclipse.hyades.logging.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984838Z" globalInstanceId="A3EB1984000F070134352D76745E51AE" msg="Plugin org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.984915Z" globalInstanceId="A3EB1984000F074D0FCAF5384A9AA13E" msg="Finished processing plugin: org.eclipse.hyades.logging.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.985006Z" globalInstanceId="A3EB1984000F07A758B917CD339033C6" msg="Start processing plugin: org.eclipse.tptp.platform.models_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.985594Z" globalInstanceId="A3EB1984000F09F30A99F414546061D4" msg="Plugin loader: Config file for plugin: org.eclipse.tptp.platform.models_4.1.0 not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.985686Z" globalInstanceId="A3EB1984000F0A500CD46B153BB11D1A" msg="Finished processing plugin: org.eclipse.tptp.platform.models_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.985765Z" globalInstanceId="A3EB1984000F0A9F367510FC31B85A88" msg="Start processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.986371Z" globalInstanceId="A3EB1984000F0CFC70AB154B24C57728" msg="Plugin loader: Config file for plugin: org.apache.jakarta_commons_logging_1.0.3 not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.986495Z" globalInstanceId="A3EB1984000F0D793EC3863C1F326311" msg="Finished processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.986623Z" globalInstanceId="A3EB1984000F0DF85137B6611E119949" msg="Start processing plugin: org.eclipse.hyades.perfmon.agents_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.988406Z" globalInstanceId="A3EB1984000F14ED151B33BB523DA01D" msg="This plugin is dependent on org.eclipse.tptp.platform.collection.framework" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.988700Z" globalInstanceId="A3EB1984000F1615781AF495512E2314" msg="Plugin loader: Plugin: org.eclipse.tptp.platform.collection.framework not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.988794Z" globalInstanceId="A3EB1984000F16750D5568A111C9163F" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.tptp.platform.collection.framework_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.990378Z" globalInstanceId="A3EB1984000F1CA304C283DF61616250" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.990491Z" globalInstanceId="A3EB1984000F1D16679B651375AA4173" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.990582Z" globalInstanceId="A3EB1984000F1D71195BF2844A5EDE93" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.990670Z" globalInstanceId="A3EB1984000F1DC81AB9F61960615B4E" msg="Plugin org.eclipse.hyades.execution_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.990777Z" globalInstanceId="A3EB1984000F1E3377F66CC85445C47B" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.990901Z" globalInstanceId="A3EB1984000F1EAF235FADA1006399C6" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.991008Z" globalInstanceId="A3EB1984000F1F1959F7C9C015488A88" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.991126Z" globalInstanceId="A3EB1984000F1F906C5F589D240E509B" msg="Plugin org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.991682Z" globalInstanceId="A3EB1984000F21BA00BC53466F73C995" msg="Plugin loader: Config file for plugin: org.eclipse.tptp.platform.collection.framework_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.991787Z" globalInstanceId="A3EB1984000F222600C875470A6A7F62" msg="Recovery: succeeded" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.992613Z" globalInstanceId="A3EB1984000F255E76FDDB05202FE2F1" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.perfmon.agents_4.0.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.992705Z" globalInstanceId="A3EB1984000F25BC74C18B846196F62C" msg="Finished processing plugin: org.eclipse.hyades.perfmon.agents_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.992785Z" globalInstanceId="A3EB1984000F260B2695CEB306F8AE1E" msg="Start processing plugin: org.eclipse.tptp.platform.collection.framework_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.992866Z" globalInstanceId="A3EB1984000F265C21AC696662A7DAD7" msg="Plugin org.eclipse.tptp.platform.collection.framework_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.992953Z" globalInstanceId="A3EB1984000F26B306771D5F53000825" msg="Finished processing plugin: org.eclipse.tptp.platform.collection.framework_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.993032Z" globalInstanceId="A3EB1984000F27036B5A65CC6CACF8F1" msg="Start processing plugin: org.eclipse.hyades.logging.adapter_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.994834Z" globalInstanceId="A3EB1984000F2E0A6C77DFE057A3BE94" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.adapter_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.994937Z" globalInstanceId="A3EB1984000F2E747F16EB2429FCE644" msg="Finished processing plugin: org.eclipse.hyades.logging.adapter_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.995017Z" globalInstanceId="A3EB1984000F2EC342CFD66D036CF016" msg="Start processing plugin: org.junit_3.8.1" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.995558Z" globalInstanceId="A3EB1984000F30DF7430AC515A79A602" msg="Plugin loader: Config file for plugin: org.junit_3.8.1 not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.995655Z" globalInstanceId="A3EB1984000F3141792FED4B3C569CAD" msg="Finished processing plugin: org.junit_3.8.1" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.995732Z" globalInstanceId="A3EB1984000F318E048E05A84BE4148E" msg="Start processing plugin: org.eclipse.hyades.logging.parsers_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998045Z" globalInstanceId="A3EB1984000F3A934E281AA16FFABF8E" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998169Z" globalInstanceId="A3EB1984000F3B1478DF2C13391E05E4" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998253Z" globalInstanceId="A3EB1984000F3B673A5407672AA0EC99" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998345Z" globalInstanceId="A3EB1984000F3BC45F48EC58270FA0A7" msg="Plugin org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998430Z" globalInstanceId="A3EB1984000F3C19289C157D529F0B73" msg="This plugin is dependent on org.eclipse.hyades.logging.adapter" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998687Z" globalInstanceId="A3EB1984000F3D18170CDC7478631FC6" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.adapter not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998778Z" globalInstanceId="A3EB1984000F3D753CDF74D83DAC6A42" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.adapter_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-02-09T10:29:24.998866Z" globalInstanceId="A3EB1984000F3DCC0BE001213912C4C9" msg="Plugin org.eclipse.hyades.logging.adapter_4.1.0 already loaded" severity="10" version="1.0.1">
<sour
Re: GUI Playback fails on Linux ("Cannot create master named pipe") [message #53423 is a reply to message #53359] |
Thu, 09 February 2006 18:32   |
Try this:
- Quit the workbench
- Stop the agent controller if it is running
- Remove /tmp/IBMRAC/ramaster
- Start the agent controller
- Start the workbench
I got this from another post (thanks to Montagner Olivier).
See if you still get the same error in the log file after following the
above instructions.
If it still doesn't work, then try running a manual test suite and see if it
launches the manual client (a standalone SWT application should popup when
you run a manual test suite).
<user@domain.invalid> wrote in message
news:dsf891$q26$1@utils.eclipse.org...
> TPTP Runtime 4.1.0
> EMF SDK 2.1
> XSD SDK 2.1
> JRE 5.0
> /Hampus Edvardsson
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
processId="7173"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
processId="7173"
> </situation>
> </CommonBaseEvent>
Re: GUI Playback fails on Linux ("Cannot create master named pipe") [message #53740 is a reply to message #53478] |
Mon, 13 February 2006 15:49  |
> I'm not sure if I understand what running a manual test suite means.
The test execution is shared amongst all test types. By running a manual
test suite I'll be able to determine whether this is a common execution
problem or something specific to the auto gui runner.
I'll keep a watchful eye out for this. I ran into some packaging problems
when testing a newer driver on my Red Linux 9.0 box. I'll test this again
when there is a better driver out. In the mean time, I've opened the
following defect to track this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=127540
"Hampus Edvardsson" <hampus@virtutech.com> wrote in message
news:dsidrk$894$1@utils.eclipse.org...
> Ali Mehregani wrote:
> > Try this:
> > above instructions.
> The error did disappear from the log after this exercise, but the result
> when running the test suite is the same: Eclipse starts, but is not
> remote-controlled, and is shut down after a timeout.
if it
when
> /Hampus Edvardsson
FUDForum. Page generated in 0.06606 seconds
