Home » Archived » M2M (model-to-model transformation) » [ATL] ant launch.xml problem with the AntPlugin
[ATL] ant launch.xml problem with the AntPlugin [message #53352] |
Thu, 19 July 2007 05:33  |
Originally posted by: NewsgroupSPAM.iKupp.de
when i start a launch.xml ant task, i ve got the following error:
With both ant files i ve tested (my own and the copydep.build.xml).
!MESSAGE The activator org.eclipse.gmt.am3.tools.ant.AntPlugin for
bundle org.eclipse.gmt.am3.tools.ant is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.gmt.am3.tools.ant.AntPlugin for bundle
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
the copydep.build.xml copies the files to the project but with the error
message.
My launch.xml file (which should load, transform and save) only create a
blank file.
Ive installed Eclipse 3.3 on a Mac with OS X.4.10
emf 2.3.0
o.e.g.am3.tools.ant_1.0.0
atl from the website (the bundle from feb 07)
and now with o.e.m2m.atl... installed with the installer guide and files
from the cvs (its was the same error message without the cvs files before)
any ideas?
thanks
Ina
Re: [ATL] ant launch.xml problem with the AntPlugin [message #54037 is a reply to message #53596] |
Fri, 20 July 2007 12:10   |
Ina Kupp a écrit :
> Ina Kupp schrieb:
>> Ina Kupp schrieb:
>>> William Piers schrieb:
>>>> Ina Kupp a écrit :
>>>>> Hi,
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> error message.
>>>>> create a blank file.
>>>>> emf 2.3.0
>>>>> files from the cvs (its was the same error message without the cvs
>>>>> files before)
>>>>> any ideas?
>>>>> thanks
>>>>> Ina
>>>> Hello,
>>>> I'm afraid that ATL is not compatible with Eclipse 3.3 yet.
>>>> You must use Eclipse 3.2.
>>>> Regards,
>>>> William Piers
>>> ok
>>> thanks for the quick answer.
>>> Ina
>> now I installed Eclipse 3.2.2 with emf 2.2.3 and the actual atl bundle
>> and am3 from the website and its the same errormessage.
>> Do I realy need the original 3.2 or is there another problem?
>> Ina
> ok now with the eclipse 3.2 there is exactly the same error message. So
> this wasnt the solution.
> Any other ideas?
> I included for testing the am3ToolsAnt.jar in the classpath in the run
> dialog but nothing changed. And this jar File is already in the
> additional tasks & support library, and this file isnt marked as invalid
> or something like this. If I remove the jar, another error message said
> that the atl support is missing.
> Ina
Could you please check if your plugins are correctly installed ?
To do this you can open the plugin registry view and look for errors,
and check if atl and am3 plugins are present.
William Piers
Re: [ATL] ant launch.xml problem with the AntPlugin [message #54139 is a reply to message #54037] |
Fri, 20 July 2007 13:44   |
> Ina Kupp a écrit :
>> Ina Kupp schrieb:
>>>>> Ina Kupp a écrit :
>>>>>> Hi,
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> error message.
>>>>>> emf 2.3.0
>>>>>> files before)
>>>>>> any ideas?
>>>>>> thanks
>>>>>> Ina
>>>>> Hello,
>>>>> Regards,
>>>>> William Piers
>>>> ok
>>>> Ina
>>> Hi,
>>> bundle and am3 from the website and its the same errormessage.
>>> Ina
>> So this wasnt the solution.
>> Any other ideas?
>> invalid or something like this. If I remove the jar, another error
>> message said that the atl support is missing.
>> Ina
> William Piers
there are no errors shown (no red boxes with a cross inside) in the
plugin registry view.
All atl and am3 plugins are present (see list below).
But not all are active
active:
# org.atl.eclipse.adt.builder
# org.atl.eclipse.adt.debug
# org.atl.eclipse.adt.editor
# org.atl.eclipse.adt.wizard
# org.atl.eclipse.engine
# org.atl.eclipse.km3
# org.atl.engine.vm
# org.eclipse.am3.core
# org.eclipse.am3.ui
inactive (no green triangle):
# org.atl.eclipse.adt.doc.developer
# org.atl.eclipse.adt.doc.user
# org.atl.eclipse.adt.perspective
# org.atl.engine.repositories.emf4atl
# org.atl.engine.repositories.mdr4atl
# org.eclipse.am3.tools.tge
org.eclipse.gmt.atl.atl2006
org.eclipse.gmt.atl.oclquery.core
How can i change the status to active? Or is it normal that this plugins
are inactive? (in total 78 of 167 plugins are active).
Many thanks
Ina
Re: [ATL] ant launch.xml problem with the AntPlugin [message #54431 is a reply to message #54139] |
Mon, 23 July 2007 08:11   |
>> Ina Kupp a écrit :
>>> Ina Kupp schrieb:
>>>>>> Ina Kupp a écrit :
>>>>>>> Hi,
>>>>>>> for bundle org.eclipse.gmt.am3.tools.ant is invalid
>>>>>>> !STACK 0
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> the error message.
>>>>>>> emf 2.3.0
>>>>>>> and files from the cvs (its was the same error message without
>>>>>>> any ideas?
>>>>>>> thanks
>>>>>>> Ina
>>>>>> Hello,
>>>>>> Regards,
>>>>>> William Piers
>>>>> ok
>>>>> Ina
>>>> Hi,
>>>> Ina
>>> Any other ideas?
>>> run dialog but nothing changed. And this jar File is already in the
>>> Ina
>> Regards,
>> William Piers
> Hi
> active:
> # org.atl.engine.vm
> Many thanks
> Ina
active/inactive is not a problem.
But your error message seems to be an incompatibility. If you tried to
install several versions of the plugins, Eclipse could have kept an old
configuration. You can force it to rebuild configuration by launching
Eclipse with the -clean option.
William Piers
MDA Consultant, Obeo (http://www.obeo.fr)
Re: [ATL] ant launch.xml problem with the AntPlugin [message #54486 is a reply to message #54431] |
Mon, 23 July 2007 15:38  |
>>> Ina Kupp a écrit :
>>>> Ina Kupp schrieb:
>>>>>>> Ina Kupp a écrit :
>>>>>>>> Hi,
>>>>>>>> !STACK 0
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> the error message.
>>>>>>>> emf 2.3.0
>>>>>>>> any ideas?
>>>>>>>> thanks
>>>>>>>> Ina
>>>>>>> Hello,
>>>>>>> Regards,
>>>>>>> William Piers
>>>>>> ok
>>>>>> Ina
>>>>> Hi,
>>>>> Ina
>>>> Any other ideas?
>>>> Ina
>>> Hi,
>>> Regards,
>>> William Piers
>> Hi
>> active:
>> # org.atl.engine.vm
>> plugins are inactive? (in total 78 of 167 plugins are active).
>> Many thanks
>> Ina
thanks very much, this was the solution ;-), now it works.
Ina
Current Time: Mon Jul 21 21:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.46195 seconds
