Home » Eclipse Projects » Plugin Development Environment (PDE) » How to add version number suffix to a RCP build?
How to add version number suffix to a RCP build? [message #53329] Thu, 02 April 2009 10:42 Go to next message
Dear All,
I have a pde build script which will produce RCP program builds, such as:
MyWorkbench-linux.gtk.x86.zip
MyWorkbench-linux.win.x86.zip
I wish to add version suffixes to the file names. Is there any setting in
the build properties? Thank you so much!
Frank Du
Re: How to add version number suffix to a RCP build? [message #53449 is a reply to message #53329] Thu, 02 April 2009 16:55 Go to previous messageGo to next message
Try setting something like
archiveNamePrefix = ${buildId}${suffix}
You'll just need to decide a good way to get the suffix value.
-Andrew
Frank Du wrote:
> Dear All,
> in the build properties? Thank you so much!
> Frank Du
Re: How to add version number suffix to a RCP build? [message #53843 is a reply to message #53449] Mon, 06 April 2009 12:07 Go to previous messageGo to next message
Hi, Andrew,
It works perfectly! Thanks so much & have a nice day!
Frank
> -Andrew
> Frank Du wrote:
>> Dear All,
>> Frank Du
Re: How to add version number suffix to a RCP build? [message #53868 is a reply to message #53449] Mon, 06 April 2009 12:33 Go to previous message
thanks so much! it works perfectly!
Best Regards,
Frank Du
Re: How to add version number suffix to a RCP build? [message #594572 is a reply to message #53329] Thu, 02 April 2009 16:55 Go to previous message
-Andrew
Frank Du wrote:
> Dear All,
> Frank Du
Re: How to add version number suffix to a RCP build? [message #594713 is a reply to message #53449] Mon, 06 April 2009 12:07 Go to previous message
Hi, Andrew,
Frank
> -Andrew
> Frank Du wrote:
>> Dear All,
>> Frank Du
Re: How to add version number suffix to a RCP build? [message #594721 is a reply to message #53449] Mon, 06 April 2009 12:33 Go to previous message
Best Regards,
Frank Du
Previous Topic:Another one of those warnings...
Next Topic:How is eclipse tested and built periodically?
Current Time: Sat Jul 12 22:13:09 EDT 2025
Powered by FUDForum. Page generated in 0.06633 seconds
