Home » Archived » XML Schema Definition (XSD) » How to get resolvedModelGroupDefinition()?
How to get resolvedModelGroupDefinition()? [message #53312] Mon, 27 September 2004 02:53 Go to next message
Originally posted by: annasser.breathe.com
I have got an XSD Schema which has only one model group definition given
below:
...other elements .....
<group name = "XYZ">
<sequence>
<element name = "A" type = "sd:String" />
<element name = "B" type = "xsd:String" />
</sequence>
</group>
......other elements .....
The above group definition is used by various elements by means of a Ref.
For example:
<complexType name = "PQ" >
<sequnec>
<group ref ="xsd:XYZ" />
<element name = "C" type = "someType" />
</sequence>
<element name = "Me" type = "PQ" />
I want to list element named "Me" as the Parent and its children which are
elements "A,B, and C", any help!!!
/Anne
Re: How to get resolvedModelGroupDefinition()? [message #53420 is a reply to message #53312] Mon, 27 September 2004 08:03 Go to previous messageGo to next message
Anne,
If you look only at XSDParticle.getTerm, you should see only the
resolved model groups, element declarations, or wildcards.
Anne wrote:
>Hi,
>below:
> <sequence>
> </sequence>
></group>
>For example:
><sequnec>
></sequence>
>/Anne
Re: How to get resolvedModelGroupDefinition()? [message #53551 is a reply to message #53420] Mon, 27 September 2004 20:39 Go to previous messageGo to next message
Marks,
This is what I have done:
Void getChildren(XSDElementDeclaration element)
XSDComplexTypeDefinition xType =
(XSDComplexTypeDefinition)element.getTypeDefinition();
XSDParticle particle = (XSDParticle)xType.getContentType();
XSDTerm term = parcticle.getTerm();
if ( term instanmceof XSDModelGroup){ // Do some processing }
else if ( term instanceof XSDElementDeclaration){ //Do some Processing }
else if ( term instanceof XSDModelGroupDefinition)
XSDModelGroupDefinition group = (XSDModelGroupXDefinition)term;
XSDModelGroup mGroup = group.getResolvedModelGroupDefinition();
// Process the model group particles as a recursive call
else { // Do some thing }
The rest works fine but I cannot get the elements declared in the group
named "XYZ" as part of the "PQ"'s model group.
HOW DO I analyse [ <group ref ="xsd:XYZ" /> ] declaration.
/anne
Ed Merks wrote:
> Anne,
> Anne wrote:
> >Hi,
> >below:
> > <sequence>
> > </sequence>
> ></group>
> >For example:
> ><sequnec>
> ></sequence>
> >/Anne
Re: How to get resolvedModelGroupDefinition()? [message #53606 is a reply to message #53551] Tue, 28 September 2004 07:10 Go to previous message
--------------030508010805090105050706
Anne,
Since XSDParticle.getTerm can only return an XSDWildcard, XSDModelGroup,
or XSDElementDeclaration, you shouldn't need an XSDModelGroupDefinition
case. I would expect that your case for XSDModelGroup will need to
process its contents recursively via XSDModelGroup.getParticles.
Anne wrote:
>Marks,
>Thanks,
>/anne
>Ed Merks wrote:
>>Anne,
>>Anne wrote:
>>>Hi,
>>>below:
>>> <sequence>
>>> </sequence>
>>></group>
>>>For example:
>>><sequnec>
>>></sequence>
>>>/Anne
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Anne,<br>
<br>
XSDModelGroup, or XSDElementDeclaration, you shouldn't need an
XSDModelGroupDefinition case.
Re: How to get resolvedModelGroupDefinition()? [message #591772 is a reply to message #53312] Mon, 27 September 2004 08:03 Go to previous message
Anne,
Anne wrote:
>Hi,
>below:
> <sequence>
> </sequence>
></group>
>For example:
><sequnec>
></sequence>
>/Anne
Re: How to get resolvedModelGroupDefinition()? [message #591849 is a reply to message #53420] Mon, 27 September 2004 20:39 Go to previous message
Marks,
/anne
Ed Merks wrote:
> Anne,
> Anne wrote:
> >Hi,
> >below:
> > <sequence>
> > </sequence>
> ></group>
> >For example:
> ><sequnec>
> ></sequence>
> >/Anne
Re: How to get resolvedModelGroupDefinition()? [message #591884 is a reply to message #53551] Tue, 28 September 2004 07:10 Go to previous message
Anne,
Anne wrote:
>Marks,
>Thanks,
>/anne
>Ed Merks wrote:
>>Anne,
>>Anne wrote:
>>>Hi,
>>>below:
>>> <sequence>
>>> </sequence>
>>></group>
>>>For example:
>>><sequnec>
>>></sequence>
>>>/Anne
<html>
<head>
<title></title>
</head>
Anne,<br>
<br>
Previous Topic:XSDSchema.resolveTypeDefinition on redefined schema
Next Topic:removing global elements from XSDSchema
Current Time: Wed Jul 30 15:24:51 EDT 2025
Powered by FUDForum. Page generated in 0.10817 seconds
