Home » Archived » Visual Editor (VE) » Installation problem - no 'Visual Class' option
Installation problem - no 'Visual Class' option [message #53280] Mon, 02 August 2004 08:01 Go to next message
Originally posted by: mark.buckland.bt.com
Hi there,
I've looked through this group and the FAQ but couldn't find any answers, so
hopefully someone can help....
I've unzipped:
http://download.eclipse.org/downloads/drops/R-3.0-2004062512 08/eclipse-SDK-3.0-win32.zip
http://download.eclipse.org/tools/emf/downloads/drops/2.0/R2 00406280827/emf-sdo-runtime-2.0.0.zip
and
http://download.eclipse.org/tools/gef/downloads/drops/R-3.0- 200406251257/GEF-runtime-3.0.zip
(the recommended downloads) from:
http://download.eclipse.org/tools/ve/downloads/drops/S-1.0M2 -200407301410/index.html
Eclipse starts up fine but I don't get the option to create a new Visual
Class. Under the Manage Configuration option the Visual Editor 1.0.0 is
lised and the Java EMF Model 1.0.0 is listed as a child. GEF 3.0 is not
visible here but is listed under Help/PluginDetails.
The log contains an error, but I'm unsure if it is relevant as it has not
occured repeatedly with each new startup of Eclipse, I'll include the log at
the bottom of this mail.
I would be grateful if anyone could help here!
Mark.
!SESSION Jul 19, 2004
16:43:01.424 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
!ENTRY org.eclipse.ui.intro 4 0 Jul 19, 2004 16:43:01.424
!MESSAGE Intro tried accessing a NULL bundle.
!ENTRY org.eclipse.ui.intro 4 0 Jul 19, 2004 16:43:05.469
!SESSION Aug 02, 2004
12:18:07.960 ---------------------------------------------
!ENTRY org.eclipse.ui 4 4 Aug 02, 2004 12:18:07.960
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Aug 02, 2004 12:18:07.970
!MESSAGE Argument not valid
!STACK 0
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:2677)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.graphics.Image.init(Image.java:1351)
at org.eclipse.swt.graphics.Image.<init>(Image.java:161)
at org.eclipse.ui.forms.widgets.FormText.paint(FormText.java:77 8)
at org.eclipse.ui.forms.widgets.FormText.access$3(FormText.java :762)
at org.eclipse.ui.forms.widgets.FormText$2.paintControl(FormTex t.java:226)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:82)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:80 3)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3020 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3338 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 67)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2429)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.update.internal.ui.RestartDialog.openQuestion(Re startDialog.java
:55)
org.eclipse.update.internal.ui.UpdateUI.requestRestart(Updat eUI.java:325)
org.eclipse.update.internal.ui.views.FeatureStateAction.run( FeatureStateActi
on.java:73)
org.eclipse.update.internal.ui.views.ConfigurationView$Previ ewTask.run(Confi
gurationView.java:343)
org.eclipse.update.internal.ui.views.ConfigurationPreview$2. linkActivated(Co
nfigurationPreview.java:78)
at org.eclipse.ui.forms.widgets.FormText.activateLink(FormText. java:746)
org.eclipse.ui.forms.widgets.FormText.handleMouseClick(FormT ext.java:631)
at org.eclipse.ui.forms.widgets.FormText.access$9(FormText.java :615)
at org.eclipse.ui.forms.widgets.FormText$6.mouseUp(FormText.jav a:282)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:136)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: Installation problem - no 'Visual Class' option [message #53307 is a reply to message #53280] Mon, 02 August 2004 09:56 Go to previous messageGo to next message
I should have mentioned that I also have installed 'eclipse-JDT-SDK-3.0.zip'
which lets me work with Java fine.
Mark.
Re: Installation problem - no 'Visual Class' option [message #53361 is a reply to message #53307] Mon, 02 August 2004 10:05 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
If you have eclipse SDK you don't need jdt sdk. Eclipse SDK already
includes JDT.
Have you used the VE before? When you say no option to create visual
class, where were you looking for this?
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #53388 is a reply to message #53361] Mon, 02 August 2004 10:09 Go to previous messageGo to next message
Hi Rich,
Thanks for replying. I havn't used VE before. I'm looking to create visual
class by right clicking on my project, and selecting the 'New' Menu.
Mark.
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:celhkd$kec$3@eclipse.org...
> includes JDT.
> Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #53414 is a reply to message #53388] Mon, 02 August 2004 11:47 Go to previous messageGo to next message
It should of showed up. Is there anything in the .log file?
Also, on manage configurations, GEF should of shown up not as a
subfeature of Visual Editor, but it should of been in the list at the
same level as Visual Editor. If not, then maybe you aren't configured
correctly.
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #53467 is a reply to message #53414] Mon, 02 August 2004 12:42 Go to previous messageGo to next message
The log file only has one other entry which details not being able to access
the update site (my development machine has no internet connection) - I
tried to 'update' when I was trying to work out what was wrong.
GEF isn't a child of 'Visual Editor 1.0.0', only 'Java EMF Model 1.0.0'
which also has the child 'WTP EMF Integration Core 1.0.0' which has the
child 'WTP Common Utilities'.
GEF is unpacked into ecclipse/plugins/org.eclipse.gef_3.0.0/ (I've double
checked that all the files are present).
As to your earlier note about JDT working, well, upon initally downloading
just Eclipse there wasn't an option for a new Java Project. This was only
availabe after installing the JDT SDK. Perhaps this may help you.
So, I guess the question now is - how can I correctly configue my Eclipse
install?
Mark.
news:celni1$qn$1@eclipse.org...
> correctly.
> Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #53521 is a reply to message #53467] Mon, 02 August 2004 13:54 Go to previous messageGo to next message
That means you didn't get the Eclipse SDK the first time, you got the
Eclipse runtime instead. I don't think Eclipse Runtime+JDK is
sufficient, I think you need to get the Eclipse SDK. I think there are
other things that VE needs that aren't in the runtime+JDT combination.
I would suggest getting the Eclipse SDK, installing it, then start your
eclipse once using the -clean option. This will tell it to ignore the
old configuration and refresh it with the new one.
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #53627 is a reply to message #53521] Mon, 02 August 2004 15:04 Go to previous messageGo to next message
Originally posted by: mark.buckland.bt.spam.me.not.com
Ok, problem solved.
I renamed the eclipse folder to eclipse.old and extracted the Eclipse SDK
and other dependencies for VE.
Restarting eclipse with -clean still did not work. I then tried a new
project and low and behold, I had the New Java Visual Class option.
Perhaps both steps was needed for the solution! Though it was a bit of a
pain having to re-import the Java files and set-up jar libraries.
FYI, GEF still isn't a child of 'Visual Editor 1.0.0' in the Product
Configuration window.
Thanks for your help.
- Mark.
news:celuvu$d2s$1@eclipse.org...
> Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #53677 is a reply to message #53627] Mon, 02 August 2004 15:51 Go to previous messageGo to next message
GEF isn't supposed to be a child of VE, it is a co-requirement, just
like EMF is a co-requirement.
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #55216 is a reply to message #53677] Sat, 07 August 2004 21:52 Go to previous messageGo to next message
Originally posted by: anon.anon.com
For the record, I'm having the same issue. Can we update the
downloads/docs to include the fix for this??
Re: Installation problem - no 'Visual Class' option [message #55242 is a reply to message #53627] Sat, 07 August 2004 21:55 Go to previous messageGo to next message
Mark, how do you restart with the '-clean' option??
Mark Buckland wrote:
> Ok, problem solved.
> - Mark.
>>Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #55268 is a reply to message #55242] Sun, 08 August 2004 19:48 Go to previous messageGo to next message
eclipse -clean
Thanks in Advance...
IchBin
_____________________________________________
'Black holes are where God divided by zero.'
-Steven Wright, comedian (1955- )
Re: Installation problem - no 'Visual Class' option [message #55374 is a reply to message #55216] Mon, 09 August 2004 11:34 Go to previous message
The docs do say use Eclipse SDK right on the the build page (Eclipse
build eclipse-SDK-3.0)
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596392 is a reply to message #53280] Mon, 02 August 2004 09:56 Go to previous message
Mark.
Re: Installation problem - no 'Visual Class' option [message #596404 is a reply to message #53307] Mon, 02 August 2004 10:05 Go to previous message
includes JDT.
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596413 is a reply to message #53361] Mon, 02 August 2004 10:09 Go to previous message
Hi Rich,
Mark.
> includes JDT.
> Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596421 is a reply to message #53388] Mon, 02 August 2004 11:47 Go to previous message
correctly.
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596438 is a reply to message #53414] Mon, 02 August 2004 12:42 Go to previous message
install?
Mark.
> correctly.
> Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596455 is a reply to message #53467] Mon, 02 August 2004 13:54 Go to previous message
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596479 is a reply to message #53521] Mon, 02 August 2004 15:04 Go to previous message
Ok, problem solved.
- Mark.
> Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596489 is a reply to message #53627] Mon, 02 August 2004 15:51 Go to previous message
Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #596993 is a reply to message #53677] Sat, 07 August 2004 21:52 Go to previous message
Re: Installation problem - no 'Visual Class' option [message #597009 is a reply to message #53627] Sat, 07 August 2004 21:55 Go to previous message
> Ok, problem solved.
> - Mark.
>>Thanks, Rich Kulp
Re: Installation problem - no 'Visual Class' option [message #597014 is a reply to message #55242] Sun, 08 August 2004 19:48 Go to previous message
eclipse -clean
IchBin
Re: Installation problem - no 'Visual Class' option [message #597067 is a reply to message #55216] Mon, 09 August 2004 11:34 Go to previous message
Thanks, Rich Kulp
Previous Topic:VE Tabs and Menus
Next Topic:Change class to visual class
Current Time: Sun Jul 13 19:36:17 EDT 2025
Powered by FUDForum. Page generated in 0.18374 seconds
