Home » Eclipse Projects » GEF » EMF or GEF?
EMF or GEF? [message #53260] Thu, 09 January 2003 18:54 Go to next message
Originally posted by: s_nedunuri.yahoo.com
Hello, I originally posted this question in eclipse.tools but someone
suggested it might be better posted here. So here goes
Quite simply, I am investigating the possibility of building a rudimentary
plug-in for
modeling using UML Activity Diagrams (that is editing the diagrams and
carrying out code generation). I have looked at both GEF and EMF and their
capabilities but I am still not sure which I need.
The EMF description on the home page seems to imply that EMF, EMF.Edit and
EMF.Codegen are together sufficient. (Tangential question: Is the EclipseUML
plugin from Omondo
then an *example* of a plugin for editing UML Class Diagrams?)
However, the GEF
overview says that "GEF is suitable for creating a wide variety of
applications, including: flow builders, GUI builders, UML diagram editors
(such as work-flow and class modeling diagrams)"
So my question is: Does EMF alone provide what I need or do I also need GEF?
Re: EMF or GEF? [message #53316 is a reply to message #53260] Thu, 09 January 2003 21:11 Go to previous messageGo to next message
For this kind of tool you would benefit from both EMF and GEF. You can use
EMF/EMF.Edit to implement your model and outline view. You can also use the EMF
codegen framework to build your generator. GEF can be used to implement the
diagrams. Omondo's EclipseUML is an example. It's implemented using both EMF
and GEF.
Frank.
> plug-in for
> plugin from Omondo
> However, the GEF
Re: EMF or GEF? [message #56542 is a reply to message #53316] Mon, 20 January 2003 11:27 Go to previous messageGo to next message
Originally posted by: oro7d3.netscape.net
You mention "You can also use the EMF codegen framework to build your
generator" , what if i want to add/modify an existing Java file in a Java
project(e.g. add/change a new attribute/method/innerclass) . Should i use
JDT's AST or EMF codegen framework?
"Frank Budinsky" <frankb@ca.ibm.com> wrote in message
news:3E1E2BBE.247D1A08@ca.ibm.com...
the EMF
the
EMF
> and GEF.
> Frank.
rudimentary
> > plug-in for
their
and
EclipseUML
> > plugin from Omondo
> > However, the GEF
editors
GEF?
Re: EMF or GEF? [message #56778 is a reply to message #56542] Mon, 20 January 2003 17:14 Go to previous message
Oro,
If you want to add relatively complicated patterns and merge them into existing
code, then the EMF codegen framework could be helpful. If your additions are
simple, however, you're probably better off to just use JDT. If you want to
change existing methods in the class (that weren't generated by the EMF
generator), you can only do that using JDT.
Frank.
> the EMF
> the
> EMF
> > and GEF.
> > Frank.
> rudimentary
> > > plug-in for
> their
> and
> EclipseUML
> > > plugin from Omondo
> > > However, the GEF
> editors
> GEF?
Previous Topic:Font Style in draw2D label
Next Topic:Property change
Current Time: Thu Jul 17 22:26:42 EDT 2025
Powered by FUDForum. Page generated in 0.04030 seconds
