php.ini file [message #53179] |
Wed, 19 September 2007 14:02  |
Originally posted by: trichins.omniture.com
I downloaded the 1.0 version recently and set up a simple phpinfo()
script. Running it, it says that my php.ini file is located in:
C:\Documents And Settings\<username>\Local Settings\Temp\php.ini
When I change that file, the changes just disappear. If I delete it, it
is recreated. I've tried following the directions at
http://us.php.net/configuration to specify a location for the php.ini.
If I run php -i from the command line, it is showing the correct
php.ini. But eclipse keeps getting it wrong.
Any ideas? I have PHP5.2.4 and PHP4.4.7 installed and it is a Windows
XP box.
Trevan
Re: php.ini file [message #53311 is a reply to message #53179] |
Thu, 20 September 2007 03:48  |
Originally posted by: seva-eclipse.zend.com
Trevan,
This php.ini file is a copy of the file located near your php.exe executable, your launch configuration set up with.
On Wed, 19 Sep 2007 12:02:09 -0600 Trevan <trichins@omniture.com> wrote:
T> I downloaded the 1.0 version recently and set up a simple phpinfo()
T> script. Running it, it says that my php.ini file is located in:
T>
T> C:\Documents And Settings\<username>\Local Settings\Temp\php.ini
T>
T> When I change that file, the changes just disappear. If I delete it, it
T> is recreated. I've tried following the directions at
T> http://us.php.net/configuration to specify a location for the php.ini.
T> If I run php -i from the command line, it is showing the correct
T> php.ini. But eclipse keeps getting it wrong.
T>
T> Any ideas? I have PHP5.2.4 and PHP4.4.7 installed and it is a Windows
T> XP box.
T>
T> Thanks,
T>
T> Trevan
Seva Lapsha
[slapsha@dev.eclipse.org]
Zend Eclipse Developer
FUDForum. Page generated in 0.24634 seconds
