Home » Eclipse Projects » DTP » Error: Method can be called only once.
Error: Method can be called only once. [message #53125] Wed, 04 March 2009 14:46 Go to next message
Using the DataSource plugin, I have connected to my Informix database and
I am able to display rows using the context menu (right-click -> DATA ->
Sample Contents.
However, if I open a SQL scrapbook window and enter a simple query:
ex. select * from table where pk = 123;
Then I get the selected row, followed by an endless stream of the message
"Method can be called only once."
The query never completes, it is necessary to cancel the operation
manually.
I have included the two system error log entries that occur when the query
is executed.
Config information:
eclipse.buildId=M20090211-1700
-vm C:\Program Files\Java\jre6\bin\client\jvm.dll
Let me know if there is other information that will help.
Michael Giroux
Log Entries:
Message from system error log follows:
java.version=1.6.0_12
Framework arguments: 384M
Command-line arguments: -os win32 -ws win32 -arch x86 384M -data
c:/EclipseWorkspace/Trunk
Error
Wed Mar 04 12:35:51 GMT-07:00 2009
The command
(" org.eclipse.datatools.sqltools.sqleditor.ExecuteAsOneStateme ntAction ")
is undefined
java.lang.Exception
org.eclipse.jface.action.ExternalActionManager$CommandCallba ck.isActive(ExternalActionManager.java:369)
org.eclipse.jface.action.ActionContributionItem.isCommandAct ive(ActionContributionItem.java:646)
org.eclipse.jface.action.ActionContributionItem.isVisible(Ac tionContributionItem.java:702)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :753)
org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuM anager.java:464)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.ja va:459)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager .java:485)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:235)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.jav a:4111)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3815 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1576)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1937)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:250)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:3849)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3416)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Error
The command
(" org.eclipse.datatools.sqltools.sqleditor.ExecuteCurrentActio n ") is
undefined
java.lang.Exception
Re: Error: Method can be called only once. [message #53590 is a reply to message #53125] Fri, 13 March 2009 10:45 Go to previous message
Originally posted by: brianf.sybase.com
Hey Michael...
Can you provide a bit more detail here? What version of Eclipse & DTP are
you using?
--Fitz
"Michael Giroux" <michael_giroux@choicehotels.com> wrote in message
news:a0ed8503c45abf244c794d4f5beb753b$1@www.eclipse.org...
> Sample Contents.
> manually.
> is executed.
> Config information:
> Regards
> Michael Giroux
> Log Entries:
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Error
> The command
> is undefined
> java.lang.Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error
> The command
> undefined
> java.lang.Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Error: Method can be called only once. [message #594698 is a reply to message #53125] Fri, 13 March 2009 10:45 Go to previous message
Hey Michael...
you using?
--Fitz
> Sample Contents.
> manually.
> is executed.
> Config information:
> Regards
> Michael Giroux
> Log Entries:
> Error
> The command
> is undefined
> java.lang.Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error
> The command
> undefined
> java.lang.Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Reverse engineer DBSchema to XSD
Next Topic:How do I create a Connection Profile
Current Time: Sat Jul 26 01:48:42 EDT 2025
Powered by FUDForum. Page generated in 0.05691 seconds
