Home » Eclipse Projects » Nebula » Grid - Columnheader / JFace Tableviewer Columnheader
Grid - Columnheader / JFace Tableviewer Columnheader [message #53098] Thu, 15 May 2008 08:45 Go to next message
Hello there.
Comparing the grid with a JFace tableviewer one big difference is quite
obvious. While a JFace tableviewer is filling the remaining space up
with a "dummy column header" the nebula grid doesn't draw anything on
the remaining space. In terms of visual acceptance it would be nice if
the grid paints such a "dummy column header" as well.
Is this possible?
Thanks.
Peter
Re: Grid - Columnheader / JFace Tableviewer Columnheader [message #53124 is a reply to message #53098] Thu, 15 May 2008 09:16 Go to previous message
I'd suggest porting the TableColumnLayout from JFace this way you can
ensure that the whole space available is always used.
By the way how SWT-Table-Control use the space depends on your OS. E.g.
on GTK the last column is simply resized to fillup the gap.
Tom
Peter Pfeifer schrieb:
> Hello there.
> Is this possible?
> Thanks.
> Peter
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Grid - Columnheader / JFace Tableviewer Columnheader [message #589880 is a reply to message #53098] Thu, 15 May 2008 09:16 Go to previous message
Tom
> Hello there.
> Is this possible?
> Thanks.
> Peter
Previous Topic:Grid - Columnheader / JFace Tableviewer Columnheader
Next Topic:Gantt Widget 2.0 - Any Requests?
Current Time: Tue Jul 22 12:08:13 EDT 2025
Powered by FUDForum. Page generated in 0.24434 seconds
