Home » Modeling » EMF » Problem with IEditorInput(IEditorInput)
Problem with IEditorInput [message #525936] |
Thu, 08 April 2010 10:57 |
Darie Moldovan Messages: 18 Registered: April 2010 |
Hello everyone,
I read several posts on dev.eclipse.org about how to use IEditorInput, but there still are some things which I cannot get to work in my project.
I'm in a similar situation as the person who wrote this topic.
I'm trying to create an XML Editor plugin for Eclipse which has 2 pages (it's a multi page editor) - page 1, where you can edit xml source code and page 2, where you can see the xml as a TreeViewer (and edit it, of course, by right click, add element, delete element ...).
What I want to do is to make any change from one of those pages visible in the other, without saving the actual file on the hard drive. So when I edit something in the source code and change the page, the tree should update (and vice-versa). I already implemented this part and it works fine. Now I tried to implement the other "direction", when editing the tree, the changes should be visible in the source code.
I should mention that I am working with DOM and when I make a change, I also edit the dom and pass it to the other view. So the org.w3c.dom.Document object always holds the actual content of the text editor / tree editor.
This part works only half, because I want to set the input of the text editor, but I need an object of the type IEditorInput, in order to say
textEditor.setInput(newInput);
Ok, so I said to myself, I'll write my own class, say "MyEditorInput", which implements IEditorInput and has a field of type org.w3c.dom.Document.
Ok, now the question: how should I use this class? How do I set the input of the text editor (which is a subclass of org.eclipse.ui.editors.text.TextEditor) if I have an object of type org.w3c.dom.Document?
Thank you for your time.
Re: Problem with IEditorInput [message #525967 is a reply to message #525936] |
Thu, 08 April 2010 12:15 |
Jonas Helming Messages: 699 Registered: July 2009 |
first a question: did you have a look at XText? they might provide what
you are looking for, without having to write pure XML. Also the are
dealing with updates between text artifacts and models. At EclipseCon
the even presented a syncornization between GMF and XText. I ask this
because there are some problems in the synchronization between models
and text, especially if the model is not valid in the textual presentation.
Second to your question: I maybe do not really understand your problem.
I also use a subclas of EditorInput for my editor, which includes a new
field. I would simply implement IEditorInput and offer a parameter in
the constructor to pass the dom.document and save it to a field. The
implementation of the other interface methods is straight forward.
Inside your custom editor you handle the custom editorinput and get the
dom.document out of it. Sounds easy but maybe i missed your real issue :-)
Cheers
Jonas
darie17 wrote:
> Hello everyone,
> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 7996.html
> topic.
Re: Problem with IEditorInput [message #525980 is a reply to message #525967] |
Thu, 08 April 2010 12:53 |
Ed Merks Messages: 33142 Registered: July 2009 |
XSDEditor, the XSD models' sample editor, does something crudely
similar. In general you can't expect an existing editor to deal with
your specialized IEditorInput. You'd need to convert the model to text
and update the text being displayed by your editor instance; you'd not
change the editor input itself. The Web Tools project has a structured
source editing framework that might better suit your needs.
Jonas wrote:
> what you are looking for, without having to write pure XML. Also the
> are dealing with updates between text artifacts and models. At
> EclipseCon the even presented a syncornization between GMF and XText.
> I ask this because there are some problems in the synchronization
> between models and text, especially if the model is not valid in the
> problem. I also use a subclas of EditorInput for my editor, which
> includes a new field. I would simply implement IEditorInput and offer
> a parameter in the constructor to pass the dom.document and save it to
> a field. The implementation of the other interface methods is straight
> forward. Inside your custom editor you handle the custom editorinput
> and get the dom.document out of it. Sounds easy but maybe i missed
> your real issue :-)
> Cheers
> Jonas
> darie17 wrote:
>> Hello everyone,
>> work in my project.
>> topic.
>> the source code.
>> to say
Ed Merks
Re: Problem with IEditorInput [message #525982 is a reply to message #525967] |
Thu, 08 April 2010 13:15 |
Hi Jonas,
first of all thank you for your answer.
Yes, I first tried to work with xtext, but due to some problems (long history...), I decided to do some things by myself.
Ok, suppose I wrote my class as follows:
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IPersistableElement;
import org.w3c.dom.Document;
public class XMLEditorInput implements IEditorInput {
private Document domDocument;
public XMLEditorInput(Document domDocument)
this.domDocument = domDocument;
public boolean exists() {
// TODO Auto-generated method stub
return false;
public ImageDescriptor getImageDescriptor() {
return null;
public String getName() {
return null;
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return null;
public Object getAdapter(Class adapter) {
return null;
public boolean equals(Object obj) {
if (super.equals(obj)) {
return true;
if (obj instanceof XMLEditorInput) {
return domDocument.equals(((XMLEditorInput) obj).getDomDocument());
return false;
public int hashCode() {
return domDocument.hashCode();
* @return the domDocument
public Document getDomDocument() {
return domDocument;
* @param domDocument the domDocument to set
public void setDomDocument(Document domDocument) {
Then, in the MultiPageEditor class I tried to change the input of the text editor as follows:
XMLEditorInput myInput = new XMLEditorInput(treeViewer.getDOM());
// treeViewer.getDOM() returns the org.w3c.dom.Document Object, which holds the actual content
textEditor.setInput(myInput);
I got no exception, but the tab where the source code should appear looks something like this.
What should I understand from this error? I checked that the dom file, which I give as a parameter is not null and has the right contents. So not the dom file is the problem.
And, what I did not understand is how the text editor should know that it should read the content of the dom file in the XMLEditorInput class. Or did I forget to explicitly call a method?
Thanks again.
[Updated on: Thu, 08 April 2010 13:17] Report message to a moderator
Re: Problem with IEditorInput [message #526026 is a reply to message #525982] |
Thu, 08 April 2010 14:42 |
Use the debugger to step through the call. No doubt the editor checks
for subclasses such as IStorageEditorInput and IFileEditorInput.
Failing to find anything it recognizes what do do with, it decides: "I
have no clue how to pull text out of what's been handed to me."
darie17 wrote:
> Hi Jonas,
> @Override
> return false;
> @Override
> return null;
> @Override
> return null;
> @Override
> return null;
> @Override
> return null;
> @Override
> return null;
> @Override
> return true;
> return false;
> @Override
> return domDocument;
> http://img176.imageshack.us/img176/6967/17211477.jpg
> Thanks again.
Ed Merks
Re: Problem with IEditorInput [message #526077 is a reply to message #526065] |
Thu, 08 April 2010 15:56 |
--------------060406050806090908010104
Comments below.
darie17 wrote:
> Ed Merks wrote on Thu, 08 April 2010 11:14
>> It seems clear to me that it's impossible for the text editor to know
>> what to do with your specialized input.
> You are right, the question is why?
I don't understand why you would expect this to work?
> What do I do wrong?
I've already told you that changing the editor's input isn't the right
thing to do. The editor's input not only determines what the editor
will display, it determines where/how the results are stored.
> I tried debugging for the last several hours and didn't learn anything
> new.
Really? You've used the debugger to get to code that looked like this?
public IDocumentProvider getDocumentProvider(IEditorInput
editorInput) {
IDocumentProvider provider= null;
IFile file= (IFile) editorInput.getAdapter(IFile.class);
if (file != null)
provider= getDocumentProvider(file.getFileExtension());
if (provider == null) {
Set set= (Set) findInputTypeMapping(editorInput.getClass());
if (set != null) {
IConfigurationElement entry=
selectConfigurationElement(set);
provider= getDocumentProvider(entry);
return provider;
> I simply cannot find the source of the error, which is, in most cases,
> worst than if you know where the mistake is, but don't know how to fix
> it...
I think you need to update the text shown by the editor, not change its
input.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Comments below.<br>
<br>
darie17 wrote:
<blockquote cite="mid:hpktad$me7$1@build.eclipse.org" type="cite">Ed
<br>
<blockquote type="cite">It seems clear to me that it's impossible for
the text editor to know what to do with your specialized input.
<br>
</blockquote>
<br>
<br>
You are right, the question is why?</blockquote>
I don't understand why you would expect this to work?<br>
<blockquote cite="mid:hpktad$me7$1@build.eclipse.org" type="cite"> What
do I do wrong?</blockquote>
will display, it determines where/how the results are stored.<br>
<blockquote cite="mid:hpktad$me7$1@build.eclipse.org" type="cite"> I
new. </blockquote>
Really? You've used the debugger to get to code that looked like this?<small><br>
</small>
<blockquote><small> public IDocumentProvider
getDocumentProvider(IEditorInput editorInput) {</small><br>
<br>
<small> IDocumentProvider provider= null;</small><br>
<br>
<small> IFile file= (IFile)
editorInput.getAdapter(IFile.class);</small><br>
<small> if (file != null)</small><br>
<small> provider=
getDocumentProvider(file.getFileExtension());</small><br>
<br>
<small> if (provider == null) {</small><br>
<small> Set set= (Set)
findInputTypeMapping(editorInput.getClass());</small><br>
<small> if (set != null) {</small><br>
<small> IConfigurationElement entry=
selectConfigurationElement(set);</small><br>
<small> provider= getDocumentProvider(entry);</small><br>
<small> }</small><br>
<br>
<small> return provider;</small><br>
</blockquote>
<blockquote cite="mid:hpktad$me7$1@build.eclipse.org" type="cite">I
it...
<br>
</blockquote>
input.<br>
</body>
</html>
--------------060406050806090908010104--
Ed Merks
Re: Problem with IEditorInput [message #526182 is a reply to message #525936] |
Fri, 09 April 2010 07:23 |
Hallvard Traetteberg Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
I had a similar problem when trying to reuse the WTP's Javascript editor
for scripts stored in EMF models. It was fairly difficult to understand
which IEditorInput subclass to implement, to satisfy the editor, but I
somehow managed to make it work (not a general solution, but OK for a
proof of concept). I've included the code below. I'm afraid I cannot
answer too many questions about this at the moment, since it was written
some time ago.
Ed: You are right (as always), using the debugger is absolutely
necessary, but often difficult when the code becomes complex.
Hallvard
StringEditorInput.java
package org.eclipse.e4.emf.javascript.ui;
import java.io.InputStream;
import java.io.StringBufferInputStream;
import org.eclipse.core.resources.IStorage;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IPath;
import org.eclipse.ui.IStorageEditorInput;
public class StringEditorInput implements IStorageEditorInput {
private String id;
protected final String scriptSource;
protected final IPath storagePath;
public StringEditorInput(String id, IPath storagePath, String source) {
this.id = id;
this.storagePath = storagePath;
this.scriptSource = source;
public boolean equals(Object other) {
return other instanceof StringEditorInput &&
id.equals(((StringEditorInput)other).id);
return null;
return id;
return null; // new Element();
int pos = id.lastIndexOf('/');
return (pos > 0 ? id.substring(pos + 1) : id);
return null;
return true;
public IStorage getStorage() {
return new IStorage() {
return null;
public boolean isReadOnly() {
return false;
return StringEditorInput.this.getName();
public IPath getFullPath() {
return storagePath;
public InputStream getContents() throws CoreException {
return new StringBufferInputStream(scriptSource);
Here's how the class was used:
final IEditorInput editorInput = new StringEditorInput(resUri + "#" +
fragment, storagePath, scriptSource);
final IEditorPart editor =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(editorInput,
editorId);
editor.addPropertyListener(new IPropertyListener() {
public void propertyChanged(Object source, int propId) {
// check for changes of PROP_DIRTY from true to false, meaning the
editor saved the String
if (IEditorPart.PROP_DIRTY == propId) {
if (editor instanceof AbstractDecoratedTextEditor && (!
editor.isDirty())) {
IDocumentProvider documentProvider =
((AbstractDecoratedTextEditor)editor).getDocumentProvider();
String newSource =
documentProvider.getDocument(editorInput).get();
try {
ScriptSourceView.commitScriptText(eObject, newSource,
editingDomainProvider);
} catch (Exception e) {
log.log(Level.WARNING, "Exception setting script text to " +
newSource + ": " + e, e);
StringEditorInputDocumentProvider.java
* Copyright (c) 2009 Hallvard Traetteberg.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Hallvard Traetteberg - initial API and implementation
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.jface.text.IDocument;
import org.eclipse.jface.text.source.AnnotationModel;
import org.eclipse.jface.text.source.IAnnotationModel;
import org.eclipse.ui.editors.text.StorageDocumentProvider;
public class StringEditorInputDocumentProvider extends
StorageDocumentProvider {
public StringEditorInputDocumentProvider() {
super();
protected IAnnotationModel createAnnotationModel(Object element) throws
CoreException {
return new AnnotationModel();
protected void doSaveDocument(IProgressMonitor monitor, Object element,
IDocument document, boolean overwrite) throws CoreException {
// ((StringEditorInput)element).doSave(document.get());
Current Time: Sat Apr 27 20:32:19 GMT 2024
Powered by FUDForum. Page generated in 0.04420 seconds
