Re: Strange error [message #526094 is a reply to message #525924] |
Thu, 08 April 2010 16:28 |
Are you setting the parameter in the url or you setting it in the
parameter entry box? Do you get this exception before the parameter
dialog is displayed?
Jason
moloco wrote:
> Sorry for my bad En :blush:
> I had an exception in birt report (birt viewer servlet)
> org.eclipse.birt.report.exception.ViewerValidationException: The
> parameter "paramRegistryPL_inog" cannot be blank.
> at org.eclipse.birt.report.utility.DataUtil.validate(DataUtil.j ava:175)
> at org.eclipse.birt.report.utility.BirtUtility.handleOperation
> BUT paramRegistryPL_inog parameter is not BLANK !!
> This error happend ONLY in html mode. In PDF or XLS all OK.
> I simple try change __format in URL and all work except html format.
> Birt version is 2.5.1
> parameter description
> <scalar-parameter name="paramRegistryPL_inog" id="344">
> <text-property name="promptText">bla bla bla</text-property>
> <property name="valueType">dynamic</property>
> <property name="isRequired">false</property>
> <property name="dataSetName">dsRegistryPL_inog</property>
> <expression
> name="valueExpr">dataSetRow["Registry_id"]</expression>
> <expression
> name="labelExpr">dataSetRow["registry_name"]</expression >
> <property name="dataType">decimal</property>
> <property name="paramType">simple</property>
> <property name="controlType">list-box</property>
> <property name="mustMatch">true</property>
> <property name="fixedOrder">true</property>
> <property name="distinct">true</property>
> <structure name="format">
> <property name="category">Unformatted</property>
> </structure>
> </scalar-parameter>
FUDForum. Page generated in 0.03189 seconds
