Home » Archived » BIRT » Empty flat files
Re: Empty flat files [message #525804 is a reply to message #525651] |
Wed, 07 April 2010 20:01 |
Helmut,
Do you have headers in the flat files that have data? One option would
be to check the file size in the beforeOpen, then if the size is 0 swap
in a dummy flat file with data that can be filtered out using a
dataset/table filter.
importPackage(Packages.java.ip);
tstfile = new File(yourfullpathfilename);
if(tstfile.exists()){
fsize = tstfile.length();
if( fsize == 0 ){
//do something;
}else{
//do something else;
Jason
Helmut Neubauer wrote:
> Hello,
> I have some empty flat files as data sets (sometimes there is no data
> there) and I'm getting a "The flatfile data source is not valid"
> message. How can I get the empty data set?
> By the way, I'm also using a beforeOpen script to parameterize the flat
> file name.
> Please help. Thanks, Helmut
Re: Empty flat files [message #525988 is a reply to message #525804] |
Thu, 08 April 2010 13:13 |
Helmut Neubauer Messages: 54 Registered: July 2009 |
Member |
Jason,
thanks for your answer. I think it will help :).
I tried to use headers. Than BIRT doesn't filter this headers. How can I
filter this header using a scripted query? If I don't use scripting
sometimes BIRT displays the header in the preview, sometimes not. I
wasn't able to see the reason, yet. Can you tell me?
Ok, checking the file size is an ugly way, but I will try this. Perhaps
there will be a better way in future.
Helmut
Jason Weathersby schrieb:
> Helmut,
> if( fsize == 0 ){
> //do something;
> }else{
> Jason
>> Hello,
>> file name.
Re: Empty flat files [message #526035 is a reply to message #525988] |
Thu, 08 April 2010 14:50 |
Helmut,
I tried this with BIRT 2.5.2 and only got the error if the headers where
not present. So if you flat files always have a header then you should
not get an error if no data is in the flat file.
Jason
> Jason,
> Helmut
>> Helmut,
>> if( fsize == 0 ){
>> //do something;
>> }else{
>> Jason
>>> Hello,
>>> file name.
Re: Empty flat files (+additional question concerning CSV flat file queries with column names) [message #526561 is a reply to message #526035] |
Mon, 12 April 2010 09:44 |
Member |
Jason,
thanks, this works!
First I forgot to check "Use first line as column name indicator" in the
edit data source dialog. So BIRT told me the flat file data source isn't
valid even if I was using the headers. Now all is ok :).
Perhaps one more question, because I use headers the first time in my
CSV files in combination with BIRT: In the past I was scripting my CSV
queries like (found an example in the newsgroups, which I understand
only partially):
queryText= "select \"COLUMN_1\", \"COLUMN_2\" " +
"from " +
params["id"].value + "-1.csv" +
" : {\"COLUMN_1\",\"COLUMN_1\",DATE;\"COLUMN_2\",\"COLUMN_2\ ",INTEGER}";
Now BIRT tells me this isn't ok. I think, because I don't use the
correct names (headers). Where Do I have to use the column names? Can
you explain me how to use the flat file queries?
Helmut
> Helmut,
> Jason
>> Jason,
>> Helmut
>>> Helmut,
>>> if( fsize == 0 ){
>>> //do something;
>>> }else{
>>> Jason
>>>> Hello,
>>>> file name.
Re: Empty flat files (+additional question concerning CSV flat file queries with column names) [message #526696 is a reply to message #526561] |
Mon, 12 April 2010 15:48 |
Helmut
The column names must match what you have in the flat file, unless you
are not using the first line for headers. Ie you should have something
like:
COLUMN_1,COLUMN_2
111,222
In your flat file.
The query text just has the column names that you are selecting and from
which flatfile. After the : is a list of each column available in the
flat file. These will be in the {} and separated by ;. Each column
will have name alias and type separated by ,.
Jason
> Jason,
> thanks, this works!
> only partially):
> "from " +
> Helmut
>> Helmut,
>> Jason
>>> Jason,
>>> Helmut
>>>> Helmut,
>>>> if( fsize == 0 ){
>>>> //do something;
>>>> }else{
>>>> Jason
>>>>> Hello,
>>>>> file name.
Current Time: Tue Sep 24 00:46:24 GMT 2024
Powered by FUDForum. Page generated in 0.03372 seconds
