Home » Language IDEs » AspectJ » AJDT 1.2.0RC2 released for Eclipse 3.0
AJDT 1.2.0RC2 released for Eclipse 3.0 [message #53004] Fri, 03 June 2005 17:10
Originally posted by: mchapman.uk.ibm.com
This is it, your last chance to get fixes into AJDT 1.2! Please try out
this build and help ensure that AJDT 1.2 is as good as possible. If no
critical bugs are found by late next week, the final release will be made.
See the AJDT download page for more information:
http://www.eclipse.org/ajdt/download.html
The build identifier is "1.2.0.20050603170108". It should appear in the
update list if you currently have an earlier build installed and search
for updates to installed features.
Compared with 1.2.0RC1, the AJDT documentation in the help system has been
completely overhauled, so please check it out (only the "What's New" page
is left to be completed). Also the following bugs have been fixed:
76365 Error "Compilation unit name must end with .java" on copy...
88474 Add/Organize imports doesn't work for Aspect-only references
92482 Rename refactor of aspect fails
92496 Multiple "Build Aspect Project" toolbar button
93532 NPE when converting a project with plugin nature but no p...
95086 Eclipse hang due to "Build configuration update build menu"
95370 AJDT renames files .aj that don't contain aspect constructs.
95726 Cross references menu entry
96089 missing source in ui plugin
96276 NLS cleanup
96450 Rename "injar" aspects to "binary"
98125 Build triggered by non-source file changes
98260 Missing file filter popup
Please see Bugzilla for more details. You can query the fixed bugs
yourself by searching for a target of "1.2.0 RC2".
Matt + the rest of the AJDT team.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Previous Topic:java.lang.AbstractMethodError when invoking introduced method
Next Topic:AJDT 1.2.0RC2 released for Eclipse 3.0
Current Time: Tue Jul 22 06:32:39 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
