Home » General (non-technical) » Eclipse Foundation » Ant Task implementing BuildListener does not work from eclipse???
Ant Task implementing BuildListener does not work from eclipse??? [message #52971] Mon, 31 March 2008 15:16 Go to next message
Originally posted by: patrick.laplante.cmcelectronics.ca
I have a plugin that contains ANT tasks. One of these task implement
org.apache.tools.ant.BuildListener
All the tasks are working fine except the one implementing BuildListener.
I receive:
BUILD FAILED
Test.xml:18: The following error occurred while executing this line:
java.lang.LinkageError: org/apache/tools/ant/BuildEvent
when launching the target inside eclipse. Some interesting observation:
This task works when the target is launched from outside eclipse.
Hope someone can help
thanks
Re: Ant Task implementing BuildListener does not work from eclipse??? [message #52994 is a reply to message #52971] Mon, 31 March 2008 20:25 Go to previous message
Patrick,
Please ask using the eclipse.platform newsgroup. This newsgroup is for
asking questions about the operations of the Eclipse foundation.
Patrick laplante wrote:
> BuildListener. I receive:
> BUILD FAILED
> observation: This task works when the target is launched from outside
> eclipse.
> thanks
Previous Topic:Cannot Install Any Plugins, Weird Dependency Error
Next Topic:ddf
Current Time: Mon Jul 14 05:51:39 EDT 2025
Powered by FUDForum. Page generated in 0.28606 seconds
