Re: Why is resourceSet.createResource(fileURI) always returning null ? [message #524690 is a reply to message #524677] |
Thu, 01 April 2010 19:12 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------070106020204000700010408
Content-Type: text/plain; charset=UTF-8; format=flowed
Aravind,
Again the debugger will help answer questions like this faster than me.
You'd step through this method and realize that you've not registered a
resource factory that can deal with your URI.
public Resource createResource(URI uri, String contentType)
Resource.Factory resourceFactory =
getResourceFactoryRegistry().getFactory(uri, contentType);
if (resourceFactory != null)
Resource result = resourceFactory.createResource(uri);
getResources().add(result);
return result;
else
return null;
aravind wrote:
> Why is the below code returning null even while running from eclipse.
> The javadoc says "If there is no registered factory, null will be
> returned; when running within Eclipse, a default XMI factory will be
> registered, and this will never return null."
> I am running eclipse Galileo Build id: 20090920-1017
> ResourceSet resourceSet = new ResourceSetImpl();
> URI fileURI = URI.createFileURI(new
> File("c:/response.xml").getAbsolutePath());
> Resource respResource = resourceSet.createResource(fileURI);
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Aravind,<br>
<br>
me. You'd step through this method and realize that you've not
registered a resource factory that can deal with your URI. <br>
<br>
<blockquote><small> public Resource createResource(URI uri, String
contentType)</small><br>
<small> {</small><br>
<small> Resource.Factory resourceFactory =
getResourceFactoryRegistry().getFactory(uri, contentType);</small><br>
<small> if (resourceFactory != null)</small><br>
<small> Resource result = resourceFactory.createResource(uri);</small><br>
<small> getResources().add(result);</small><br>
<small> return result;</small><br>
<small> }</small><br>
<small> else</small><br>
<small> return null;</small><br>
</blockquote>
<br>
<br>
aravind wrote:
<blockquote cite="mid:hp2q4j$9gm$1@build.eclipse.org" type="cite">Why
is the below code returning null even while running from eclipse. The
javadoc says "If there is no registered factory, null will be returned;
when running within Eclipse, a default XMI factory will be registered,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070106020204000700010408--
Ed Merks
FUDForum. Page generated in 0.03168 seconds
