Home » Eclipse Projects » JFace » Spreadsheet-like table viewer
Spreadsheet-like table viewer [message #524119] |
Tue, 30 March 2010 20:02 |
Eric Buist Messages: 5 Registered: March 2010 |
I am trying to create a TableViewer object acting a bit like an Excel spreadsheet. With the basic table viewer, I got a table with rows and columns, and I can navigate rows by using the keyboard.
However, cell editing support is a bit limited. By default, one needs to click on the cell to trigger the editor. The idea is that the table will contain many rows and the user would like to quickly enter a value, press enter to validate it, then the down arrow key to go to the next row.
Here is how I could get the keyboard navigation:
TableViewerFocusCellManager focusCellManager = new TableViewerFocusCellManager(v, new FocusCellOwnerDrawHighlighter(v));
ColumnViewerEditorActivationStrategy actSupport = new ColumnViewerEditorActivationStrategy(v) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event) {
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType == ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTION
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.CR)
|| event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
TableViewerEditor.create(v, focusCellManager, actSupport,
ColumnViewerEditor.KEYBOARD_ACTIVATION);
Here, v is an instance of TableViewer.
The program I am working on allows to perform operations on multiple rows of the table. With the above code, I get keyboard navigation working, but multiple selection does not work anymore. In fact, it works internally, but the table viewer just does not render it; it only highlights the cell currently in focus.
Thinking that the problem could come from the focus manager, I tried to put it to null. It worked, but I lost cell editing using the keyboard.
I also tried with a code snippet Snippet035TableCursorCellHighlighter providing a TableCursor cell highlighter. This highlighted full rows, with the current cell identified by a rectangle, but yet no multiple selection.
Another possible partial solution would be to use the fact that only one column will be frequently edited in my table. If it was possible to trigger the cell editing programmatically, I could make a key listener starting the editor when the user presses the Enter key. However, as I looked through documentation and source code, doing so would require to obtain a ViewerCell, which I cannot do without knowing the position of the cell in pixels or getting a ViewerRow. But I found no public API to get a ViewerRow.
I tried very hard to work around this, without any success. I even looked at the source code of the table viewer.
This may be possible to achieve using something other that TableViewer, but this would force me to rewrite all the code dealing with the table viewer. Some possible candidates for a control would be the Nebula grid (alpha state, so may change in the future) or a plain Swing JTable, if it is possible to use one inside a SWT Composite. The second solution seems heavyweight to me and may not provide the necessary flexibility.
I am using Eclipse 3.5.
Re: Spreadsheet-like table viewer [message #524128 is a reply to message #524119] |
Tue, 30 March 2010 20:24 |
Charlie Kelly Messages: 276 Registered: July 2009 |
Hi Eric,
See the Eclipse Nebula widgets.
They might be what you are looking for.
Charlie
Eric Buist wrote:
> || event.eventType ==
> ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
> || (event.eventType ==
> || event.eventType ==
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet035TableCursorCellHighlighter.java?view=mar kup
> selection.
> get a ViewerRow.
Re: Spreadsheet-like table viewer [message #526012 is a reply to message #524128] |
Thu, 08 April 2010 14:30 |
I tried to look at Nebula Grid, but I don't like the idea that it is still in alpha state: it may have bugs I will be stuck with after I migrate or the API might change without notice in the future, forcing a lot of code rewrite. Moreover, I found no API documentation, only basic examples. According to these examples, this will work as with my current TableViewer, but I'm not sure about advanced stuff such as cell editing. Moreover, the Nebula Grid seems lower level than the TableViewer: you need to manually create GridItem objects for each row. I read about a GridViewer that would act as TableViewer for the Grid, tried to find documentation or at least code examples about it: no go. I cannot even find a download for the GridViewer; maybe the project has gone offline.
I found the NatTable widget which could be a great tool. Has anyone used this?
Re: Spreadsheet-like table viewer [message #526052 is a reply to message #526012] |
Thu, 08 April 2010 15:20 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Am 08.04.10 16:30, schrieb Eric Buist:
We haven't been breaking any API since a long time IIRC (well we fixed a
typo in 2 of our API-methods because they differed from the
SWT-Table/Tree ones) and the widget is quite stable and many companies
use it. The main problem we didn't released a 1.0 release is that we
didn't had time yet to restructure Nebula.
You are right that you might be stuck with a bug but getting a fix in to
Grid is easier than for example into Table/Tree because of the nature of
Grid (it's emulated).
If you are not comfortable with opensource support my company can offer
you professional support for Grid, ... (probably other can/would as
well) but you can naturally fix stuff your own and believe me this is
not as hard as you might think it is :-)
Still the message is Nebula-Grid has a 99.9% stable API and you can
programm safely against it's API.
Yes Grid == Table/Tree, GridViewer/GridTreeViewer ==
TableViewer/TreeViewer if you take a close look you'll notice that you
simply have to swap TableViewer through GridViewer and your code doesn't
change beside that because those features are coming from JFace.
Sticking with GridViewer your migration path is quite easy which one of
the great with things Nebula-Grid because it follows SWT/JFace-API and
Codeing style nearly 100%, you get Eclipse-Databinding-Support by
default, ...
http://www.eclipse.org/nebula/downloads.php => it comes with the Grid
download.
> this?
We once tried to get them into Nebula but well it never happened.
Tom
Re: Spreadsheet-like table viewer [message #538163 is a reply to message #524119] |
Sat, 05 June 2010 21:19 |
Mikayel Aghasyan Messages: 2 Registered: April 2010 |
I had the same problem and I've solved it by copying FocusCellOwnerDrawHighlighter and removing listener hooking stuff. In a result I have the following class:
public class MyFocusCellHighlighter extends FocusCellHighlighter {
* Create a new instance which can be passed to a
* {@link TreeViewerFocusCellManager}
* @param viewer
* the viewer
public MyFocusCellHighlighter(ColumnViewer viewer) {
super(viewer);
* The color to use when rendering the background of the selected cell when
* the control has the input focus
* @param cell
* the cell which is colored
* @return the color or <code>null</code> to use the default
protected Color getSelectedCellBackgroundColor(ViewerCell cell) {
return null;
* The color to use when rendering the foreground (=text) of the selected
* cell when the control has the input focus
* @param cell
protected Color getSelectedCellForegroundColor(ViewerCell cell) {
return null;
* cell when the control has <b>no</b> input focus
* @param cell
* @return the color or <code>null</code> to use the same used when
* control has focus
* @since 3.4
protected Color getSelectedCellForegroundColorNoFocus(ViewerCell cell) {
return null;
* the control has <b>no</b> input focus
* @param cell
* control has focus
* @since 3.4
protected Color getSelectedCellBackgroundColorNoFocus(ViewerCell cell) {
return null;
* Controls whether the whole cell or only the text-area is highlighted
* @param cell
* the cell which is highlighted
* @return <code>true</code> if only the text area should be highlighted
* @since 3.4
protected boolean onlyTextHighlighting(ViewerCell cell) {
return false;
protected void focusCellChanged(ViewerCell newCell, ViewerCell oldCell) {
super.focusCellChanged(newCell, oldCell);
// Redraw new area
if (newCell != null) {
Rectangle rect = newCell.getBounds();
int x = newCell.getColumnIndex() == 0 ? 0 : rect.x;
int width = newCell.getColumnIndex() == 0 ? rect.x + rect.width
: rect.width;
// 1 is a fix for Linux-GTK
newCell.getControl().redraw(x, rect.y - 1, width, rect.height + 1,
true);
if (oldCell != null) {
Rectangle rect = oldCell.getBounds();
int x = oldCell.getColumnIndex() == 0 ? 0 : rect.x;
int width = oldCell.getColumnIndex() == 0 ? rect.x + rect.width
: rect.width;
oldCell.getControl().redraw(x, rect.y - 1, width, rect.height + 1,
true);
Not sure if it meets your needs but you can try it.
Re: Spreadsheet-like table viewer [message #631971 is a reply to message #524119] |
Mon, 11 October 2010 06:02 |
pharmacie1801 Messages: 1 Registered: October 2010 |
You can do it by
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.F2)
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.KEYPAD_CR)
&& event.keyCode > 31 && event.keyCode < 127)
&& event.keyCode >= SWT.KEYPAD_MULTIPLY && event.keyCode <= SWT.KEYPAD_9)
this will make editor activated using any alphanumeric key
now the problem that editor will lose fist key because it's used to activate editor
so just do this
ColumnViewerEditorActivationListener listener = new ColumnViewerEditorActivationListener() {
public void afterEditorActivated(
final ViewerCell cell = (ViewerCell) event.getSource();
if (pedit[cell.getColumnIndex()].editor.getControl() instanceof Text) {
Text tt = (Text) pedit[cell.getColumnIndex()].editor
.getControl();
if ((event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED
tt.setText("" + event.character);
tt.setSelection(tt.getText().length());
//--------------- complete it then
v.getColumnViewerEditor().addEditorActivationListener(listener);
[Updated on: Mon, 11 October 2010 06:03] Report message to a moderator
Current Time: Mon Apr 29 07:26:47 GMT 2024
Powered by FUDForum. Page generated in 0.03351 seconds
