Retrieve port and host from IConnectionProfile [message #52891] |
Tue, 03 March 2009 11:41  |
Originally posted by: andi.hotz.adsl.li
Hello
I figured out a great deal of how DTP works with the help from this
newsgroup or on my own. Thanks.
There is still a question I can't find an answer. Based on an
IConnectionProfile I can retrieve the connection URL through
getBaseProperties(). For some databases this connection string contains
the a port number and a host. The connection URL is part of the
properties defined with the database connection. The exact format of the
connection URL varies with the vendors (i.e. MySQL vs. Oracle). What I
need in my application is the port number and the host name. Is there a
way to retrieve these from a IConnectionProfile or must I write a vendor
specific parser for the connection string?
Cheers
Andy
Re: Retrieve port and host from IConnectionProfile [message #53399 is a reply to message #53152] |
Wed, 11 March 2009 13:00  |
Thanks Brian
It was not the answer I hoped for but anyway....
I implemented a parser for the connection URLs. For anyone who is in the
same need, the parser can be found at
http://codegenjava.svn.sourceforge.net/viewvc/codegenjava/tr unk/ch.sahits.codegen.java.datatools/src/ch/sahits/codegen/u til/DTPConnectionParser.java
The JUnit for the class is at
http://codegenjava.svn.sourceforge.net/viewvc/codegenjava/tr unk/ch.sahits.codegen.test/src/ch/sahits/codegen/java/util/D TPConnectionParserTest.java.
Cheers Andy
Brian Fitzpatrick wrote:
> Hi Andy!
> Unfortunately, because of the way JDBC works and the variations of the JDBC
> URL, there isn't a great way to figure out the host and port without having
> some prior knowledge of what database system you're going after.
> Sorry... I wish I could help more.
> The various sample URLs for the vendors are listed in the driver template
> definitions in DTP's enablement projects, so if you do a search for
> "driverTemplate" in plugin.xml in the Enablement projects. You can at least
> that way get an example of the various styles/forms of URLs for the DBMS's
> that DTP handles.
> Good luck! Glad the info in the community has helped thus far!
> --Fitz
> "Andi Hotz" <andi.hotz@adsl.li> wrote in message
> news:gojmjh$52q$1@build.eclipse.org...
>> Hello
>> the a port number and a host. The connection URL is part of the properties
>> defined with the database connection. The exact format of the connection
>> URL varies with the vendors (i.e. MySQL vs. Oracle). What I need in my
>> application is the port number and the host name. Is there a way to
>> retrieve these from a IConnectionProfile or must I write a vendor specific
>> Cheers
>> Andy
Re: Retrieve port and host from IConnectionProfile [message #594516 is a reply to message #52891] |
Thu, 05 March 2009 09:47  |
Hi Andy!
that DTP handles.
--Fitz
> Hello
> Cheers
> Andy
Re: Retrieve port and host from IConnectionProfile [message #594619 is a reply to message #53152] |
Thanks Brian
Cheers Andy
> Hi Andy!
> that DTP handles.
> --Fitz
>> Hello
>> Cheers
>> Andy
FUDForum. Page generated in 1.06576 seconds
