Home » Archived » EPF » a question about epf rich edit:
a question about epf rich edit: [message #52887] Fri, 22 August 2008 05:30 Go to next message
Originally posted by: dbzhou.huawei.com
I have one question about EPF Rich Edit.
When I add a Hyper link from EPF rich editor ,if the linked address has
Chinese words, the rich edit will translate the address into another
code,so I can not link to the right address.
for example, I want to http://myweb/ÈíŒþ¿ª·¢ÏîÄ¿¶šÒå±ê׌.doc, EPF
change it to
" http://myweb/%8F6F%4EF6%5F00%53D1Ïî%76EE%5B9A%4E49±ê%51C 6.doc",But it's
Wrong! It doesn't work.
What can I do?
BTW, when I use RMC7.0,It's OK.
TIA
Re: a question about epf rich edit: [message #52966 is a reply to message #52887] Fri, 22 August 2008 11:56 Go to previous message
Originally posted by: storaskar.xx.xxx.xxx
Which EPF version are you using ?
Have you tried on latest RMC ?
If it's still issue with latest EPF version (try 1.5 nightly/milestone
build), please file a bugzilla.
Re: a question about epf rich edit: [message #590230 is a reply to message #52887] Fri, 22 August 2008 11:56 Go to previous message
Previous Topic:a question about epf rich edit:
Next Topic:catch the "return" key
Current Time: Mon Jul 21 20:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.02476 seconds
