Home » Archived » EPF » catch the "return" key
catch the "return" key [message #52860] Fri, 22 August 2008 05:15 Go to next message
Hi !
I would like to catch the return key in the rich text tab of an
RichTextEditor to insert a new line. For now, it just "simulates" the
pressing of the [OK] button.
I tried to add a keylistener to the RichTextEditor object but special keys
such as return key or backspace key are not catched. I also tried to
implements my class from KeyListener with no results.
Does anyone have some ideas to fix this ?
I also noticed that some key events are not catch in the keyPressed
function but they are in the keyReleased function. Does anyone know why ?
thanks in advance,
Aline
Re: catch the "return" key [message #52941 is a reply to message #52860] Fri, 22 August 2008 09:08 Go to previous messageGo to next message
Aline wrote:
> Hi !
> keys such as return key or backspace key are not catched. I also tried
> to implements my class from KeyListener with no results.
If you're talking about placing a RichTextEditor in a JFace Dialog, then
the answer is to override
org.eclipse.jface.dialogs.Dialog.createButtonsForButtonBar(C omposite)
and change the way it creates the OK button (pass false as the final
argument to createButton() instead of true).
Hope this helps,
Eric
Re: catch the "return" key [message #53014 is a reply to message #52941] Sat, 23 August 2008 14:57 Go to previous message
Yeah !!! thx a lot !
Re: catch the "return" key [message #590213 is a reply to message #52860] Fri, 22 August 2008 09:08 Go to previous message
Aline wrote:
> Hi !
Hope this helps,
Eric
Re: catch the "return" key [message #590254 is a reply to message #52941] Sat, 23 August 2008 14:57 Go to previous message
Previous Topic:a question about epf rich edit:
Next Topic:How to provide link to a file
Current Time: Mon Jul 21 22:29:11 EDT 2025
Powered by FUDForum. Page generated in 0.04652 seconds
