Home » Archived » XML Schema Definition (XSD) » maxlength value missing
maxlength value missing [message #52836] Tue, 14 September 2004 14:21 Go to next message
Originally posted by: robinnt.us.ibm.com
I am trying to build an anonymous simple type with a maximum length
restiction. The maxLength facet is being added to the simpleType however the
value is not shown. Do I need to do anything else in the code for this to
work? I am using the xsd-SDK-M200407211027 build.
This is the XSD fragment I am trying to build:
<xsd:element name="CLASS_CODE" nillable="true">
<xsd:simpleType name="string">
<xsd:annotation />
<xsd:restriction base="xsd:anySimpleType">
<xsd:whiteSpace value="preserve" />
<xsd:maxLength />
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
Here is the code:
XSDSimpleTypeDefinition simpleType =
xsdFactory.createXSDSimpleTypeDefinition();
simpleType.setBaseTypeDefinition(derivedSchema.getSchemaForS chema().
resolveSimpleTypeDefinition(XSDConstants.SCHEMA_FOR_SCHEMA_U RI_2001,
xsdType));
dbColumnElement.setAnonymousTypeDefinition(simpleType);
XSDMaxLengthFacet maxLengthFacet =
xsdFactory.createXSDMaxLengthFacet();
maxLengthFacet.setValue(charLength); //set length value here
but is not shown in xsd file
simpleType.getFacetContents().add(maxLengthFacet);
Thank you, Robin
Re: maxlength value missing [message #52890 is a reply to message #52836] Tue, 14 September 2004 14:40 Go to previous messageGo to next message
Robin,
You need to call setLexicalValue rather than setValue; the value is
computed from the lexical value. (When in doubt, try to find something
equivalent in XSDPrototypicalSchema.)
> <xsd:annotation />
> <xsd:maxLength />
> </xsd:restriction>
> </xsd:simpleType>
></xsd:element>
>Here is the code:
>xsdType));
>Thank you, Robin
Re: maxlength value missing [message #52943 is a reply to message #52890] Tue, 14 September 2004 15:16 Go to previous message
Thanks Ed that worked!!
Robin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ci7do7$i1v$1@eclipse.org...
> Robin,
the
> > <xsd:annotation />
> > <xsd:maxLength />
> > </xsd:restriction>
> > </xsd:simpleType>
> ></xsd:element>
> >Here is the code:
> >xsdType));
here
> >Thank you, Robin
Re: maxlength value missing [message #591570 is a reply to message #52836] Tue, 14 September 2004 14:40 Go to previous message
Robin,
> <xsd:annotation />
> <xsd:maxLength />
> </xsd:restriction>
> </xsd:simpleType>
></xsd:element>
>Here is the code:
>xsdType));
>Thank you, Robin
Re: maxlength value missing [message #591590 is a reply to message #52890] Tue, 14 September 2004 15:16 Go to previous message
Robin
> Robin,
the
> > <xsd:annotation />
> > <xsd:maxLength />
> > </xsd:restriction>
> > </xsd:simpleType>
> ></xsd:element>
> >Here is the code:
> >xsdType));
here
> >Thank you, Robin
Previous Topic:XSDXPathDefinition
Next Topic:Derivation by restriction
Current Time: Fri Jul 25 22:32:28 EDT 2025
Powered by FUDForum. Page generated in 0.06908 seconds
