editor tabs re-ordered when switching tasks [message #52824] |
Wed, 16 July 2008 09:32  |
When I open several editors under a given task context they appear from
left to right in a certain order. When I switch tasks and then switch
back to my original task context the editors are in a different order.
This means that I have to keep searching for the class that I want. Is
this actually the expected behaviour? Is this a bug or is this just a
limitation of Eclipse.
Re: editor tabs re-ordered when switching tasks [message #55983 is a reply to message #55101] |
Wed, 13 August 2008 17:10  |
> Along the same line, Eclipse allows the user to arrange editor tabs in
> distinct panes in the main editor window, but associating editor tabs in
> panes, associating that arrangement with a context in a task, then
> deactivating then reactivating that task results in totally blowing-away
> the pane arrangement.
> Upon activating a task, all files in the context are reopened in one pane,
> possibly in a different order, as mentioned.
> Steffen, I don't suppose the workbench memento mechanism can handle editor
> pane arrangement / layout?
Yes, if I restart Eclipse with two editors side by side the workbench
restores the original layout. I would assume that the workbench layout is
stored separately from the open editors but I am not sure.
A similar request for restoring the layout on task activation has been made
here:
244075: restore dual editor panes upon task reactivation if previously
working in dual pane mode
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244075
Steffen
Re: editor tabs re-ordered when switching tasks [message #591247 is a reply to message #52824] |
Wed, 16 July 2008 10:02  |
I see the same behaviour, and it is annoying. It makes me hesitate to
change active tasks.
Re: editor tabs re-ordered when switching tasks [message #591262 is a reply to message #52824] |
Thu, 17 July 2008 02:42  |
Mylyn uses the workbench memento mechanism to restore editors on task
activation. I am not sure if that preserves the order of editors. Derek,
please go ahead and file a new bug:
http://www.eclipse.org/mylyn/bugs/
Steffen
Re: editor tabs re-ordered when switching tasks [message #592105 is a reply to message #52907] |
Thu, 31 July 2008 17:55  |
Re: editor tabs re-ordered when switching tasks [message #592445 is a reply to message #55101] |
here:
Steffen
FUDForum. Page generated in 0.42429 seconds
