Home » Eclipse Projects » DTP » SQL Editor doesn't list my DB connection
SQL Editor doesn't list my DB connection [message #52810] Fri, 20 February 2009 16:40 Go to next message
Originally posted by: dserodio.gmail.com
I've updated my MySQL Driver Definition with the location of the JAR,
and successfully created a new connection on the Data Sources Explorer.
Then I create a new SQL Scrapbook and choose MySql_5.0 in the Connection
profile's "Type" field, but "Name" field is empty so I can't choose my
existing connection.
What am I doing wrong? I'm using the Ganymede release.
Thanks in advance,
Daniel Serodio
Re: SQL Editor doesn't list my DB connection [message #52837 is a reply to message #52810] Mon, 23 February 2009 19:15 Go to previous message
Was there anything in the Name combo box when you clicked on the
drop-down arrow?
I'm not sure why, but the Name field defaults to blank when it could be
pre-filled with the Name associated with the chosen Type. The same
holds true for the Database field.
Daniel Serodio wrote:
> Thanks in advance,
> Daniel Serodio
Re: SQL Editor doesn't list my DB connection [message #594434 is a reply to message #52810] Mon, 23 February 2009 19:15 Go to previous message
drop-down arrow?
> Thanks in advance,
> Daniel Serodio
Previous Topic:SQL Editor doesn't list my DB connection
Next Topic:DTP Webinar - March 5
Current Time: Mon Jul 14 23:19:29 EDT 2025
Powered by FUDForum. Page generated in 0.04667 seconds
