Home » Archived » Voicetools » not a lot of success on the first try
not a lot of success on the first try [message #4671] Thu, 28 April 2005 22:13 Go to next message
I downloaded the zip file this afternoon and extracted it into the
eclipse/plugins directory as usual. I see the plugin in the directory
and in the list of plugins displayed by Eclipse, so it seems the very
basics are in order.
I can see “Voice Tools” in the Help Contents.
When I try the first task, to create a VXML file, the task instructions
say to choose "New > Other > Voice Tools > VoiceXML File".
Unfortunately, I do not see "Voice Tools" as an option under Other.
Is there some other configuration needed? I do not recall seeing any
instructions.
-- Mike Greenawalt
Tellme Networks
Re: not a lot of success on the first try [message #4741 is a reply to message #4671] Thu, 28 April 2005 23:01 Go to previous messageGo to next message
Thanks for checking it out! I think the documentation is just confusing :)
If you select "Other.." does the Voice Tools group appear in the dialog that
comes up? You should be able to create a VoiceXML file from there.
"Mike Greenawalt" <mgreenawalt@tellme.com> wrote in message
news:d4s5g3$tlu$1@news.eclipse.org...
>eclipse/plugins directory as usual. I see the plugin in the directory and
>in the list of plugins displayed by Eclipse, so it seems the very basics
>are in order.
> I can see
Re: not a lot of success on the first try [message #4810 is a reply to message #4741] Fri, 29 April 2005 14:27 Go to previous messageGo to next message
Thanks, Brent.
The documentation seems clear enough. The problem is that Voice Tools
does not appear in the "Other..." list.
-- Mike
>>are in order.
>>say to choose "New > Other > Voice Tools > VoiceXML File". Unfortunately,
>>instructions.
>>-- Mike Greenawalt
>>Tellme Networks
Re: not a lot of success on the first try [message #4879 is a reply to message #4810] Fri, 29 April 2005 17:45 Go to previous messageGo to next message
When you open Help->About Eclipse Platform->Plug-in Details, does the plugin
ID "org.eclipse.vtp.editor.vxml" appear in the list? That contributes the
wizard entry you should see. I installed the VTP from scratch on top of the
M3 WTP+GEF+EMF+etc build, Win32 build available here:
http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/S-1.0M3-200502260707/wtp-eclipse-prereqs-sd k-1.0M3-win32.zip&url=http://download.eclipse.org/webtoo ls/downloads/drops/S-1.0M3-200502260707/wtp-eclipse-prereqs- sdk-1.0M3-win32.zip&mirror_id=1
When I select File->New->Other.. the dialog that comes up has the voice
tools group. (Screenshot attached) An alternative to using the wizards is
just to create a new simple file (File->New->Other...->Simple->File) and use
the extension .vxml.
I'm curious, are you using the Win32 builds of WTP? I am not sure if we have
tested the contribution on other platforms.
news:d4tuis$2g6$1@news.eclipse.org...
> Thanks, Brent.
> -- Mike
>> that
>>>are in order.
>>>I can see
  • Attachment: dialog.gif
    (Size: 29.17KB, Downloaded 257 times)
Re: not a lot of success on the first try [message #4976 is a reply to message #4879] Fri, 29 April 2005 21:33 Go to previous messageGo to next message
Uh-Oh. My bad.
I overlooked the prerequisite statement, so I did not get the webtools
build first.
I will tackle that on Monday.
-- Mike
>>Thanks, Brent.
>>-- Mike
>>>that
>>>>are in order.
>>>>instructions.
>>>>-- Mike Greenawalt
>>>>Tellme Networks
Re: not a lot of success on the first try [message #5044 is a reply to message #4976] Tue, 03 May 2005 14:09 Go to previous message
Great! It worked as advertised when I got the webtools version installed.
-- Mike
Mike Greenawalt wrote:
> Uh-Oh. My bad.
> build first.
> -- Mike
Re: not a lot of success on the first try [message #571642 is a reply to message #4671] Thu, 28 April 2005 23:01 Go to previous message
>are in order.
> I can see
Re: not a lot of success on the first try [message #571662 is a reply to message #4741] Fri, 29 April 2005 14:27 Go to previous message
Thanks, Brent.
-- Mike
>>are in order.
>>instructions.
>>-- Mike Greenawalt
>>Tellme Networks
Re: not a lot of success on the first try [message #571692 is a reply to message #4810] Fri, 29 April 2005 17:45 Go to previous message
> Thanks, Brent.
> -- Mike
>> that
>>>are in order.
>>>I can see
    (Size: 29.17KB, Downloaded 192 times)
Re: not a lot of success on the first try [message #571724 is a reply to message #4879] Fri, 29 April 2005 21:33 Go to previous message
Uh-Oh. My bad.
build first.
-- Mike
>>Thanks, Brent.
>>-- Mike
>>>that
>>>>are in order.
>>>>instructions.
>>>>-- Mike Greenawalt
>>>>Tellme Networks
Re: not a lot of success on the first try [message #571750 is a reply to message #4976] Tue, 03 May 2005 14:09 Go to previous message
-- Mike
> Uh-Oh. My bad.
> build first.
> -- Mike
Previous Topic:Voice Tools Project mailing list
Next Topic:vtp with webtools-M4 ?
Current Time: Tue Jul 22 01:35:56 EDT 2025
Powered by FUDForum. Page generated in 0.08097 seconds
