Home » Language IDEs » Java Development Tools (JDT) » some fundamental basic usage questions
some fundamental basic usage questions [message #52754] Sun, 08 June 2003 15:05 Go to next message
Originally posted by: vnssoftware.myway.com
1. I have the Classpath in a .bat file. Its a large one with all the
folder and jar files. I just want to copy and paste it somewhere in
eclipse and that's the place which it should use for running my
project. I just want to run. It tells me Add external Jars..etc. I
just want to copy and paste the classpath I already have.
2.Anyway..I chose my folders/jars manually..and I got-
Error occurred during initialization of VM
java/lang/NoClassDefFoundError: java/lang/Object
In External Jars I had put the jars I require. Specified JDK as 1.3.1.
Does it need the tools.jar etc to be specified also. What step should
I take?I do have multiple jvms but i selected the 1.3.1.
3.I want to have a Hotkey in Windows 2000 which will allow me to get
"System.out" on the line in the Editor I press the Hotkey.How can I do
this using Eclipse Editor? Hotkey can be like Ctrl-F-F2.
This will help me not to write System.out everytime or even do Ctrl-C
and Ctrl-V each time.
Any help? - Thank you.
Re: some fundamental basic usage questions [message #52808 is a reply to message #52754] Sun, 08 June 2003 16:37 Go to previous message
You must specify a standard "JRE" library. I guess you added the rt.jar
file.
try "sysout" + <CTRL+space>
Genady
Previous Topic:New project - default directory
Next Topic:How to modify method modifier!
Current Time: Tue Jul 15 11:55:09 EDT 2025
Powered by FUDForum. Page generated in 0.10106 seconds
