Home » Archived » Test and Performance Tools Platform (TPTP) » Non-Java System Under Test and Hyades
Non-Java System Under Test and Hyades [message #4655] Wed, 02 February 2005 08:51 Go to next message
Originally posted by: sadkar.avaya.com
I'm a newbie to Hyades.
1. Can we test a non-Java application (SUT) using Hyades? The SUT may be
an executable/binary of the code in C/C++ generating traces/logs.
2. How can we convert these logs to generate Test Cases using Hyades?
Thanks in advance.
Shrirang
Re: Non-Java System Under Test and Hyades [message #5989 is a reply to message #4655] Thu, 17 February 2005 21:22 Go to previous message
Shrirang,
Eclipse TPTP project can be extended to support testing of non-Java
applications. You would have to implement extensions to make this happen.
Joe Toomey and I are going to teach a tutorial on just the topic at the
upcoming EclipseCon 2005 conference. You can get an advance copy of the
presentation by visiting the link below.
http://www.eclipse.org/tptp/test/documents/tutorials/eclipse Con2005/EclipseCon2005_Tutorial6.pdf
This should point you in the right direction.
-Sri
"Shrirang Adkar" <sadkar@avaya.com> wrote in message
news:ctqlu7$ah6$1@www.eclipse.org...
> Hello,
> Thanks in advance.
> Shrirang
Previous Topic:Generating models using EMF
Next Topic:Attention EclipseCon attendees interested in TPTP
Current Time: Sun Aug 17 15:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.03313 seconds
