Re: Birt Crashes Runtime Error on Preview [message #521704 is a reply to message #521540] |
Thu, 18 March 2010 14:28 |
Greg,
When you downloaded the Galileo for Java and Report Developers which one
did you use SR1 or SR2? SR2 was released late feb. I have downloaded
all version of Galileo and can not reproduce your error. What os are
you running?
Jason
Greg wrote:
> I downloaded Birt with Eclipse Galileo and tried to create a report, and
> I used a different instance of Eclipse Galileo and installed Birt using
> Eclipse Update, and I get the same result.
> I created a Data Source and a Data Set. I am able to view my Data when
> I create the Data Set so I don't think that is the problem. (I also
> tried the default database included with Birt and that didn't work
> either) I add a simple table and add a column from my dataset to that
> table, and when I select preview, I get this error, "A runtime Error has
> occurred on Line 1897". It then goes to a Class is undefined error on
> Line 15. It also has an error on line 495 that says,
> "birtParameterDialog" is null or not an object.
> When I select Run Report, the browser that popups says it is unable to
> display the webpage.
> So what is going on here? I am using Eclipse Galileo Java EE IDE for
> Web Developers. My installed JRE is jre.1.6.0_05. I also have the same
> issue with Eclipse Galileo for Java and Report Developers which was the
> actual installation that included BIRT.
> I have also tried this using jre and jdk 1.5.
> I am finding Birt to be extremely buggy and unusable. Doesn't anybody
> know the solution to this? Thanks.
FUDForum. Page generated in 0.03572 seconds
